Question about E-Machines Computers & Internet
It appears our computer has no power... we've tested the outlet and it worked fine a few minutes ago...
    President:
  • 948 Answers
Your power supply has probably failed. Replacement should be around $50 at a shop. Less than $20 if you do it yourself.
Posted on Jun 30, 2009
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
I have a whirlpool AWZ7303 with no heat. i have tested the element and the 2 thermostats either side with my meter set on the buzzer and they all buzzed. i tested the outlet thermostat at the front of the...
I sent you a clarification request a few minutes ago. I read your question a few more times. If your meter is set to ohms (continuity) with the buzzer or sound, then you should get continuity on the operating thermostat. Do this; go back to the operating thermostat and tap it a few times with the handle of a screwdriver or something and retest. See if you have continuity then. If you do have after doing that, then try the dryer again.
Even so, if this does work at least you know the problem and I would replace it anyway. It sounds as if your element and other thermostats are fine as you suggested. Let me know if you can.
Mike
Aug 07, 2011 | Whirlpool AWZ7303 Electric Dryer
Machine will not turn on. Worked fine 12 hours ago
Have you checked for power at the outlet?or maybe try and unplug for few minutes and plug back in to outlet or another outlet...also outlet maybe gfci protected,look for reset button on outlet or in main breaker panel.
Jul 26, 2011 | Keurig Elite B40 Coffee Maker
I've had my my Logitech speakers for a few months now and they've worked fine up until a few weeks ago. Now if I turn the volume up more than a quarter of the way the sound goes scratchy and...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Logitech X-540 Computer Speakers
My samsung syncmaster 920nw picuture goes blank after a period of a couple of minutes. If I turn the power off and then back on the picture re-appears but goes off again. It is not he pc since it works...
If you get a flashing screen which show your screen for few minutes and then goes blank it may be an issue with the Monitor.
Try to restart the computer and go to BIOS setup screen. If you experience the same issue in BIOS then the monitor needs a repair or replacement for sure.
Jul 19, 2010 | Samsung SyncMaster 920NW Monitor
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
May 31, 2010 | Nintendo Wii Console
TV appears dead
the mainboard is damaged and need to be replaced
Jul 09, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Computers & Internet Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
