ERROR CODE F11 ON A COLD FILL MACHINE - Washing Machines
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 code on whirlpool washer
    Motor bearing has gone and heating up so that the position/speed sensor has moved/melted causing the machine to jump about. needs new motor bearings/ new motor.
    Dec 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
    The F11 error can be difficult to resolve even for us technician's.
    The F11 error occurs when the central control and motor control don't talk to each other.
    If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
    Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F11 washer stops mid-cycle
    The F11 code means that communication between the CCU circuit board at the top of the machine and the motor control circuit board at the bottom of the machine has been lost. The problem most often found is cold solder joints on the CCU board that make and break causing the F11 code and sometimes an FdL code. To fix this you need to remove the CCU circuit board at the top of the machine and have the larger solder points of the relays and the spade connectors resoldered. If your not to handy with soldering you could just print out this response and a good appliance repair shop should be able to help you out. Good Luck.
    Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Stops on spin cycle and gives a f11 error code
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
    Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
    Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
    Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    Kenmore Elite HE3T washing machine code F11
    Kenmore Elite HE3T washing machine error code F28, what does this mean?
    Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
    WT714 error code f11
    F-11 ERROR MEANS:  Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.-------
    to resolve the error check out:
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
    May 04, 2009 | Washing Machines
    Hotpoint wt741 f11 what does this mean
    Hotpoint Error Codes.
    Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
    Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
    One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
    These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
    # F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
    Dec 26, 2008 | Washing Machines
    Washing Machines Logo
    75 people viewed this question
    Top Washing Machines Experts
