Question about LG enV VX9900 Cellular Phone
Dust under the screen
My son's Nokia 6085 has a lot of dust under the screen - how can I clean this out?
  • 66 Answers
I wouldnt try... take it to a "phone doctor" they can remove the screen and clean it out
Posted on Jun 30, 2009
I need the restriction code for my nokia 6085
Hi you can try Simpleunlocking.com to get restriction code for your Nokia 6085 and get it unlocked..
Feb 20, 2012 | Nokia 6085 Cellular Phone
Have a JVC HD-Z886 61inch, there appears to be some black spots behind the screen. Looks like dust, most at top of screen, not a big problem. Is there any way to clean behind the screen? When new the TV...
  • The most severe problem dust can cause in an LCD TV is a short circuit. This occurs when dust enters the television's casing and settles on one or more of the internal circuit boards. Enough dust can cause a short circuit, which will prevent the TV from working at all. In other cases, it will damage picture quality or prevent certain features from working properly.
    Because a short circuit can only occur when enough dust is present inside the TV, this problem happens after the TV has been in use for a number of years, meaning that it will not be covered under the manufacturer's warranty. In many cases of short circuits, repair is expensive, and you are better off buying a new set.
  • Image Quality
  • Dust can also have an effect on an LCD TV's picture quality without entering the LCD's casing. Dust that settles on the surface can distort the picture and decrease its brightness. While it's easy to wipe the dust away, use only a soft cloth and mild cleaning solution to avoid scratching the screen or causing permanent damage with caustic cleansers.
    Dust under the screen can be more difficult to clean. Using compressed air to blow the dust out is the best option, short of disassembling the set to clean the screen from the inside. Keeping the surface of the screen free of dust is usually sufficient to prevent dust from getting under the screen.
  • Control Problems
  • Another effect dust can have on a an LCD TV occurs when it enters the space around buttons, making it difficult to control the television. On certain sets, dust will cause buttons to stick or prevent them from engaging when pressed. Using compressed air to blow the dust out, or resorting to using only the remote control, will solve this problem.
  • Jan 24, 2011 | Televison & Video
    How do I take the cover off of my Nokia 6085 to clean the dust that is caught between my screens?
    This might come in handy:
    Most Nokias, this model included, are not designed for the user to disassemble - you run the risk of damaging internal components.
    If you want to clean the dust you should get your phone opened and cleaned at a Nokia Care Centre. Getting it done anywhere else will invalidate the manufacturers warranty.
    You can find your nearest Nokia Care Centre at:
    For UK
    http://www.nokia.co.uk/A4228006
    For Europe:
    http://europe.nokia.com/A4388379
    For Asia-Pacific
    http://www.nokia-asia.com/A4416070
    Elsewhere:
    http://www.nokia.com select your country, go to the support section, then select repair.
    Hope it helped.
    Nov 18, 2009 | Cell Phones
    Dust inside screen how do i clean ?
    HI,
    Just took T6 and took out the 4 screws and then carefully pulled off the front cover.Then Remove whole dust from it. But Be careful. Although
    the screen cover actualy comes off with ease using a little tool. Nokia have one called the SRT6 and is £8 from here: http://www.phatphones.com/nokia-srt6-phone-opening-tool.htm
    Sep 03, 2009 | Nokia N96 Smartphone
    Dust behind cell phone screen Nokia 6085h
    you can either try an airline at a petrol station this is the old way,or the best advice is to take it to a nokia care centre.
    May 22, 2009 | Nokia 6085 Cellular Phone
    Water marks and dust on the INSIDE of Nokia 6085 LCD screen
    Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
    Mar 31, 2009 | Nokia 6085 Cellular Phone
    Dust Under Nokia 6085 Screen
    nokia6100 network sognel ok but did not communication use with some simcard
    Mar 28, 2009 | Nokia 1110 Cellular Phone
    I have a RCA 60 inch TV and its about 12 or 13 years old. It has never been serviced or cleaned on the inside. The problem I'm having is the picture is starting to fade (quite a lot)and I was wondering if...
    you probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
    the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
    Feb 18, 2009 | RCA P56950 56" Rear Projection Television
    How can I get the dust out of the screen?
    your not stuck with it. dust blower spray might get in the small cracks. or just take to local retailer and they will clean it.
    Jan 16, 2009 | Nokia 7370 Cellular Phone
    I have to clean my N73 screen
    just take it to any mobile repair shop ,and he will open the front panel of your mobile and will clean the dust,if mobile body is damaged replace your mobile body..
    or : If you know how to open the front panel of your mobile it will save your money,just use clean cloth to remove dust....
    Please let me know your feed-back.
    Thanks
    dilipbagdi
    Technical Associate
    Apr 27, 2008 | Nokia N73 Cellular Phone
    LG enV VX9900 Cellular Phone Logo
    202 people viewed this question
    Top LG Cell Phones Experts
    skiffy99
    skiffy99
    Level 1 Expert
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
