Question about Nelson L R 56610 Electronic Water Timer
Can you give me a simple way to program my system? I have two different zones, and would like to run each zone 30 minutes Mondays and Fridays. Do I set zone one on A and zone 2 on B. What about C?
    President:
  • 1,723 Answers
Do you have the manual? Just program two zones for the 'A' program. Don't need B and C. Set the time, date and all that, then set the days you want to water to 'On' . Then set the zones you are using like 1 and 2 and put in the amount of time you want it to water, like 30 minutes. That's all there is to it! Let me know... I'll help you.
Posted on Jul 02, 2009
All lines are busy
They probably are, then you need to wait a few minutes and keep trying. Or send a letter and let the person or company know that you are having a problem connecting by phone. I have called different companies at different times, and sometimes you can wait a half hour or more trying to get through. Just know that in most businesses, Mondays and Fridays are always the busiest day of the week. So try your call on Tues, Wed., or Thurs., when not so busy.
Apr 11, 2014 | SBC 410 4 Line Speakerphone with Caller...
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8845PV
Jul 15, 2012 | Hardware & Accessories
I had the unit set to a second zone that ran into a splitter for four different areas of my house. The second zone is not working, how do I test to see if it is the denon unit or the splitter ?
Plug something other than Zone 2 into the splitter, say, any tape out on the Denon. Keep it simple. Play FM.
When and if THAT works go back to the manual and analyze why Zone 2 isn't working. Observe the Zone 2 Output indicator. (Page 5)
You must have a TV or other speaker-capable device that you can run Zone 2 OUT to. Try that to prove your setup works.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-789-Receivers-manual/id/23110dj895/t/2/
Page 17, 30, 31, 57,65- 68 (you get the idea).
Jun 20, 2011 | Denon AVR-789 Receiver
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
How can I set my watch to the Newfoundland time zone? It is UTC -2:30 (Atlantic time zone plus 30 minutes)
Thank you for contacting FixYa.<br /> The EcoDrives are wonderful watches. However, they are sll very different and complex.<br /> Your best solution that I can give you is to go to their awesome website. You can download a manual and get direct support from Citizen.<br /> <a href="http://www.citizenwatches.com.au/instruction-manuals">http://www.citizenwatches.com.au/instruction-manuals</a><br /> Best regards.<br />
Aug 25, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Dec 29, 2009 | Denon AVR-1803 Receiver
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Nelson L R  56610 Electronic Water Timer Logo
438 people viewed this question
Top Nelson Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Hippy_dd
Are you a Nelson Hardware and Accessory Expert? Answer questions, earn points and help others
