The diesel and oil mixing at high rate
SOURCE: oil is mixing with diesel then splashes out
Need more input here iam afraid ,like make and model and where the leak is if the fuel is mixing with oil do not drive it could hydraulic or even worse run away with itself and just run till it blows up ,once it goes turning the key off will not stop the engine it will run on the sump oil mix and watch a con rod come through the block
SOURCE: my isuzy truck mixes diesel and engine oil. what could be the cause?
We dont have these in USA but sounds like an injector is leaking and dripping down past rings or injector pump on some are attached to engine and could be leaking back into the engine block. sorry i can't help you any more than that.
SOURCE: my isuzu truck mixes diesel and engine oil. what is the cause?
front seal on injector pump leaks into oil in 4hf1 .change seal
