FixYa.com
Tags:
Umax Astra 1200S Flatbed Scanner
How do I access the underside of the Flatbed... (by 2 users)
posted by BobW on Nov 08, 2007
The glass on the flatbed scanner, Dexxa brand, but Artec AS6E product, dropss down, and I am unable to detect anyway in which to access the 'inside' of the scanner, so I can repair or replace whatever is necessary to restore the glass so it does not drop down anymore.
The user manual provides no relief, and I can not find any way of accessing that area, ie. separate the top from the bottom, etc.
If anybody knows how to access the inside of the scanner 'box' so I can clean the bottom of the glass, and apply double-sided fibreglass tape or ??? to re-secure the glass, please advise. Thank you! Arjay
The glass in our ten year old scanner also came loose. There are two phillips head screws on the top. If you unscrew them the case comes apart. Look for screws. I'm trying to clean the adhesive off the glass and the plastic, and a suitable replacement double-sided tape.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 07, 2008
umax astra escaner 3470
Best Solution
posted on Nov 20, 2007
Helpful (85)
BeuGeste
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
problems scanning
I have a new Photosmart C7200... Answer This...
Scanners
how to put the drain hose out...
hook up the drain hose so the... Answer This...
Scanners
Scaner
I need Draive Scasi Scaner... Answer This...
Umax Astra 1200S Scanner...
When trying to scan it makes a... Answer This...
1200s scanner
I have been given a umax 1200s... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
