Fan will not come on portable window unit 110 volt
Unit will not come on portable window unit 110 volt
    Scholar:
  • 70 Answers
Fan motor may have dry or bad bearings or may be bad capacitor,burnt wire. remove case and see if motor will turn freely. If not see if it has oil ports or if you can run some oil around shaft to free it up. If it has side play in shaft it maybe too late. 3n1 oil will work or even 30w non det.
Posted on Jun 30, 2009
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
My fan burn its a 110 volt but plug it direct 220 volt i want to find out what that burn
It must be burned because the voltage requirments is only 110 volts if it goes beyond that voltage it might be that the internal fuse of the fan or either the motor is burned and itshould be recoiled or replaced.
Oct 01, 2013 | Lasko 2515 Tower Fan
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
Moved to new apt. Set up the windchaser pacr10 portable to outlet then press start the unit made a pot noise. It stop working after that. I then discover that the outlet wasn't a 110v it was a 220v. The...
Not much my friend.
Are you in the USA or other place where 110/120 volt is the norm???
How in the world did a 110 V - 15 or 20 amp outet get put on a 220 volt circuit?????
Is this a rental property? If yes, I'd be calling the land lord and if I didnt get any satisfaction there, I'd be calling the city or the county or who ever oversees rentals and I'd be calling the news paper!
If this is your house - get yourself a volt/ohm meter and check all outlets in your house and garage and outside ... If you are not sure how to do this, it would be worth the investment to have a electrician inspect this house.
I'm sorry our machine if finished and I am very glad you are not hurt.
Thanks for your interest in FixYa.com
please vote
thanks
a
Dec 11, 2009 | Windchaser PACR10 Portable Air Conditioner
Hv a tsf-49. evap fan motor not turning even temp drops @ 10 deg f. volt reading=54 volts
unit probbly needs at least 110 volts to fan in order for it to run.
Aug 03, 2009 | Freezers
Exact same thing happened to me
the 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Jul 20, 2009 | Goldstar KG6000R Window Air Conditioner
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
I have bard central unit model# a/c ph11361 blower not running
220 is just putting two 110 volt circuits together. You should read only 110 volts from each leg to ground. But you should read 220 between both legs. Measuring between two legs that are supposed to be 220 and you read nothing than you are not measuring the differences. This means you are only getting 110 volts. Check your units data plate and make sure you need 220. Usually the condenser fan on a split system is 110 volts and the condenser fan is 220 volts. Which motor are you checking?
Apr 02, 2009 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
