Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Trintron tv the color turn dark and then and thought i would check the conection.. when starting to move the tv... the picture returned to norm... but did not last..... now there is no picture.... just sound....
    Problem Solver:
  • 20 Answers
Re: trintron tv
Dear Lammy,
Turn the G2 control up, or clockwise just a hair, and see if the piture returns. The G2 or screen control is one of two controls located on the flyback, or high voltage transformer.
Please let us here from you!
Posted on Nov 08, 2007
0 characters
3 Points
My tv just blanked off and want come back on its a sony trintron 36inch color tv
do you have any audio? if you do the it's usually a fuse for the video circuit. if no sound no picture, then main fuse power supply out
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
Jan 05, 2009 | Sony KV-32S42 32" TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
JVC 27" AV27F803 Brightness fades to dark intermittently
I likely you have a loose conection in the crt board at the neck of the picture tube or a loose conection close to the high voltage transformer,I would suggest to tap the main board as well as the crt board with a wooden or rubber handle(not metal),be attentive were you tap to see if the set reacts ,if the set reacts you will need to resolder those places ,be carefull working on a set that is on while you do it,this should give some idea what the problem could be in case you want to call someone to help you with the repair.Let Us know if you need more information.
Nov 06, 2006 | JVC AV-27F803 27" TV
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Brightness and volume
The dark picture is a bad capacitor for the screen or drive voltage for the picture tube driver transistors. The other problem of streaking is one of the same. Thats the indication that a capacitors defective . It could in a rare cas ebe a defective or gassy crt as well but 99% of the time when a crt is said to be gassy its nothing more then poor drive to the crt. Good luck
Jun 13, 2006 | Mitsubishi CS-40507 40" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
77 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
