Coleman rooftop air conditioner just stopped blowing cold
It was fine yesterday but today is only blowing hot air. thank you for your time.
    Scholar:
  • 70 Answers
Make sure you don't have low voltage. washout out side coil and check that fan motor is running. Bad stat,compressor a gas leak or burn wire could be the cause.
Posted on Jun 30, 2009
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
My rooftop ac blows hot air . no cold air comes out
Have someone with knowledge of electrical systems, diagnose if compressor getting power.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Coleman...not blowing cold air
if the compressor is not turning on then your capicitor is bad they are on the top side of the a/c you will see a set of wires comeing out and there will be 2 5/16hex screws holding acess cover in
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Problem with rooftop air conditioner duo therm brisk air box kit
Try having a professional check that the collant lines have not perished. Also have them check the thermostat and that there is actually gas in the system. The warm air suggests that the unit has no gas.
Oct 30, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
