Question about Fuji Cameras
When I have my xd m+ memory card in the fujifilm finepix s700 - and turn on the camera i get a blue screen '' no image '' then when I try to take picture ''memory full'' is displayed. I know there are pictues on the card- I have tried using a card reader - the card reader does not acknowledge the xd card. I bought a 2 pack of cards - the other one works fine. This card was only used for a couple days and no pictures were removed from the card- any ideas - or suggestions = would a recover program work? any suggestions on which recover program to try?
  • dee_barlow Jun 30, 2009
    after a few tries I was able to retrieve most of my pictures from the xd picture card - using a lexar multi card reader adn the ZAR (Zero Assumption Recovery) 8.4 build 15 tool I found on this site.
    Thank you for the valuable information. I will now take the xd picture card back to the place of purchase and have it replaced.
  • Fuji Master
  • 12,267 Answers
That card is defective. return it
Posted on May 02, 2017
  • 8 Answers
SOURCE: Memory Problem
May was a long time ago - you may have solved this by now...
A330 cameras only accept certain types of xD cards.  If you have a type 'h' card, it won't work.
I have a card that says "H512mb" and it's useless.  You can only use cards with no letters before the card size or type "M"  cards.  With a type "M", you need to upgrade the camera firmware.  Read directions here: http://www.fujifilm.com/products/digital/download/a330/fupd.html
-Kelly.
Posted on Dec 17, 2007
simplemitch
  • 752 Answers
SOURCE: FinePix Image Memory Card reader DPC-R1
Usually the filename is how they are sorted, i.e., 001.jpg, 002.jpg, 003.jpg.... Check on the camera's setup menu to see what method is being used for file naming (for instance, it may be organizing based on date stamp, instead...).
Posted on Aug 05, 2008
informatica
  • 1114 Answers
SOURCE: fujifilm finepix s700 card error
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html.
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Posted on Aug 09, 2008
jerryg50
  • 1689 Answers
SOURCE: Took pictures with Olympus Stylist
It is possible that the memory card was damaged. This would be by coincidence. Just in case only the formatting is damaged you can try to format the memory card.
As far as reading the card is concerned, if the Mac has issues to read a PC format then it will not be able to read the card from your camera.
Jerry G.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: camera or memory card "CARD FULL" error
Check to see if in your settings you are putting the pictures onto the memory card or the cameras internal memory. If there is no internal memory, then I guess that's no help. Also check to see if the card is write protected (a little switch on the side of it).
Posted on Apr 13, 2009
I have a J10 fujifilm camera and it currently has an error message: FRAME NO. FULL! I have the following picture card: Fujifilm xD xD-Picture Card M1GB Any advice would be appreciated.
Try formatting the memory card. If that doesn't work, try a different memory card. If that doesn't help, sadly, it's probably time to return the camera if it's still under warranty.
Jul 13, 2011 | Fuji FinePix J10 Digital Camera
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
Will sdhc memory card work with S700?
No. The S700 works with SD and xD cards, not with SDHC cards.
Nov 20, 2010 | Fuji FinePix S700 Digital Camera
From where I can buy memory card for finepix E510 camera
The Fuji Finepix E510 takes a memory card type called "xD Picture Card". You can buy it most retail stores, but you'll save a lot of money buying online.
The Upgrade Place has low prices and a Camer Memory Finder Tool. See the capacities available and click to buy xD Picture Cards at discount prices here: FujiFilm FinePix E510 Memory Cards
May 12, 2010 | Fuji FinePix E510 Digital Camera
Screen says card error
Fujifilm FinePix E550 Card Error Problem: With camera OFF, remove XD card. Turn camera ON & "take" a couple of pictures. Turn camera OFF & reinsert the XD card. Turn on & it should be good to go. It sems strange that this info is not available on the fujifilm website where they suggest to take the camera to "the nearest authorized FUJIFILM repair facility."
Oct 02, 2009 | Cameras
Accessing internal pictures from FujiFilm FinePix S700 digital ca
Take the xd card out of the camera and then you can access the internal memory.
Dec 18, 2008 | Fuji FinePix S7000 Digital Camera
Fuji xd memory card
I had same problem especially in flash mode. I changed SD Memory card and it is now 100% good. You must always use Premier brand cards, cause others may cause problems. You must als format your card first, before changing it.
May 17, 2008 | Cameras
Blue screen
You should check the settings to see which type of memory card you are using, xD versus Compact Flash. The default xD card that the camera comes with is very small and may not support saving the size of image you're trying to capture. If you are using a card with enough memory the card itself might be defective..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
Cameras Logo
85 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
