Question about Fuji FinePix A400 Digital Camera
Camera won't connect.
I've never had a problem hooking my camera up to my computer with the USB cable until the last few times I've tried. I connected my camera but instead of opening up the menu with downloading options for my photos, I get a virus alert. This only happens the first time I connect and then the other times my computer makes the noise that it recognizes something has been hooked up but nothing happens and I can't find an icon for it, either. HELP! I'd really like to get my pictures off.
    Habit-Forming:
    New Friend:
  • 20 Answers
Try another cable or download you pictures directly from the card, inserting it in the sd slot in your computer.
Posted on Jun 03, 2017
cammedic
  • 667 Answers
SOURCE: Camera not connecting to computer
You'll need to update the camera software for use with Vista. The Vaio isn't the problem. Thee updates for the F20 can be found here: FujiUSA
Posted on Mar 16, 2008
creeperz
  • 52 Answers
SOURCE: Can't initialize SanDisk Ultra II for S7000
It looks as though the camera cannot support memory as high as 4GB. Capacities above 2.2 GB require that your camera supports "FAT32", and S7000 does not support FAT32.
Posted on Jan 01, 2009
  • 36 Answers
SOURCE: Computer does not recognize my camera
Please use another USB connecting cord as old one seems broke.
Posted on Feb 11, 2009
karan4aaki
  • 68 Answers
SOURCE: download pictures from finepix s2000 hd
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Posted on Mar 10, 2009
vortash
  • 431 Answers
SOURCE: camera will not connect with PC to download pictures
Hi I am vortash .. check for damage on your download lead and around the camera plug interface .. check that the drivers are still installed and reinstall them to make sure ... if you have a sd card installed remove it as it may be lose in the socket and the camera is trying to read it and can't .. check your batteries are ok .. try it on another computer .. if all this fails sounds like the camera interface has broken constant plugging in and out can sometimes cause problems with a loose plug .. hope tthis helps Regards Vortash
Posted on May 17, 2009
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
My computer won't offload my pictures from my camera.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 08, 2012 | Canon PowerShot A470 Digital Camera
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
Wher can I buy a usb cable for my Polaroid m737t?
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't cost much more than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 08, 2012 | Polaroid m737t Digital Camera
I have an Kodak M1033 that I use all the time and until last week I was connecting via USB to my laptop running xp. I went to download pictures this week and I keep getting the "USB device not...
Jul 20, 2011 | Kodak EasyShare M1033 - black Digital...
Hi! I've recently discovered that I cannot find my usb cable for my Polaroid t730 camera. I've looked everywhere and am worried that I cannot get a replacement. Is there anywhere that I can find a...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jun 12, 2011 | Cameras
I am trying to hook up my camera polaroid i834 to my computer so i can see my pictures and file them. i have hooked up the usb cable but my epson printer workforce 610 says connection error. i have...
Jul 09, 2010 | Polaroid i834 Digital Camera
I hook the usb cable but it still does not show my pictuers
Consider NOT connecting your camera to your computer.
Mar 30, 2008 | Kodak EasyShare C613 Digital Camera
My camera won't connect to my computer
This can be caused by several things. First plug up another USB device to that port. if it works you know your port is good. next hook up the camera and look in my computer for a extra drive letter. if you see on that is your camera. If nothing still see if you can hook it up to another persons computer to see if your cable and camera is ok. If the camera does work and none of these help out then it is a drivers issue. you will need to go into saft mode by hitting f8 when the pc first starts up goto option 3 safe mode now right click on my computer Icon and goto properties. Find device manager. in their click on hardware now find the USD devices and try to remove all of the usb listings once you have done that reboot the system the system will come up in normal mode. And start loading all of your usb devices again. Now hook up the camera and see if it works. If that does not work then in XP goto the system tools are in you accessories area. and choose system restore. choose the date closest to the last time it worked. Once you restore the system then hook up the camera again. This should work as long as all hardware is good.
Mar 07, 2008 | Kodak EasyShare C633 Digital Camera
COMPUTER WONT ACknowledge camera
Dec 22, 2007 | Pentax Optio 50 Digital Camera
Fuji FinePix A400 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
