Question about Goodman Heating & Cooling
Bi-directional heat pump dryer inline filter. Can
In line filter, bi-directional heat pump dryer . Can it be installed in the wrong line and can it cause the heat pump to operate incorrectly. The heat pump has been installed for 12 years without any problems. It is a duel fuel propane and electric heat pump. Janitrol Model CPKE 36-1.
  • 3,361 Answers
It can be installed in either direction.
Posted on Jun 30, 2009
Why should I turn on enable bi directional printer properties dialog box
If you have a bi directional printer then you can increase the print speed by enabling it in the properties. Most older printers only print in one direction and the return to a home position to print again. Bi directional printers will print in both directions so there is not wasted movement of the print head.
Jul 24, 2013 | Computers & Internet
Whirlpool clean touch dryer is not heating up. The drum turns, the filter is clean and there is suction at the filter. the dryer is running cold on all temp settings and dryer settings. The gas line has...
If you are handy you can do it yourself. There should be an ignitor near the burner. It gets red hot when you turn on the dryer. There is a bi-metal switch "looking" at the ignitor, which will cut off the ignition and at the same time energize the gas valve(s). If this is not happening, either there is no power going to the burner assembly, or the ignitor is broke (split).
May 08, 2011 | Dryers
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Not using salt
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
Jul 06, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
The place where u place the soap won't let all the soap out why
hello. i can help you.
Timer
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
Dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Feb 19, 2009 | Hoover HDC7FM Dryer
My Kenmore Elite Electic dryer mod #11063012101
OK .. on your dryer it does have a bi-metal switch that turns on and off the element....if your dryer produces heat... nothing wrong with element.. a thermostat w/wire sensor is the only way to check for your heat if its working correctly.. the other is to check if your clothes coming out of your washer is it wetter then before.. might need to spin one more time.. good luck..
Jan 13, 2009 | Kenmore 62602 Electric Dryer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Heating & Cooling Logo
169 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
