Question about Tecnik TKL9260 Front Load Washer
Kenmore Elite - 110-24942301 - Dispenses Bleach onto the Floor
I suspect that the hose has either become disconnected or is split but in order to determine this, I need to get under the top of the washer. What is the procedure to remove the top of the washer to get to the bleach hose?
2 Suggested Answers
SOURCE: Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Posted on Dec 27, 2008
I just moved and all of a sudden it won't drain completely
In the move, the removal men tipped it over and have split one of the hoses. First off check the discharge hose at the back for cracks, kinks or crushing..
Dec 30, 2015 | Kenmore Elite 45986 Front Load Washer
Why is my Kenmore Elite 655 leaking water onto the floor?
more than likely u have a leak in one of ur hoses? or cracked water pmump
Apr 04, 2015 | Kenmore Washing Machines
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Water runs out onto the floor
the drain hose is off the pipe or other hoses from the pump to the wash tub. old hoses have a split in it. could be more than just hoses.
not easy but fixable you will need to unplug the unit and take the back off and have a look see. good luck and have fun.
Dec 21, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
88 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
