Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA71 fridge and freezer suddenly stopped working
Hotpoint FFA71 we have in the garage for the last year, switched switched it back on to store some surplus and it worked fine for 2 days then suddenley stopped with the red lights all ablaze, any ideas why both fridge and freezer would stop so suddenly? Power is on everything seems the same.
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Posted on Jul 11, 2009
Hi i have FFA71 frige the freezer is not working but refrigeter is working ad ice is building
Posted on Jan 30, 2012
Hotpoint FFA71 NOT DEFROSTING
Self defrosting feature is not working. Check defrost thermostat, defrost heater, defrost timer for proper operation.
Until repair is made, defrost the unit and turn back on until it freezes up again. Check the ice block at rear of freezer. If the ice is confined to the area around the refrigeration line coming into the freezer it is low refrigerant level. If the block completely covers the evaporator it is a non working defrost mechanism.
Nov 21, 2013 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffa71
you can dampen a small part of folded to 1/2" wide paper towel, and wrap the dampened paper towel around the end of a straw, stick that in the drain hole and blow.
Apr 30, 2013 | Refrigerators
Hi There We have bought a second hand FFA71
If the refrigerator was not demonstrated as functional when purchased, you may have bought a dud.
Aug 03, 2017 | Refrigerators
Subject: Sears Craftsman 1/2 HP Garage Door Opener (Logic Board # 45308W) Hello, My unit has been working well for 20 years and has now started to “click” on and off by itself. The unit works the door...
Cold solder joints are common on these logic boards.
Using a magnifying glass, inspect the solder joints on and around the transformer. A trained eye will see the crack right away.
Resolder the solder connections and retest..
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
Jan 11, 2009 | Hotpoint Refrigerators
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
1,235 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
