Question about Lenovo 3000 N500 Notebook
Not Starting I bought Lenovo 3000 N 500 15 days back. From Yesterday, it has stopped working and shows the following message:Broadcom UNDI PXE- 2.1. v11.0.11Copyright(C) 2000-2008 Broadcom CorporationCopyright (C) 1997- 2000 Intel CorporationAll rights reservedPXE- E61: meida test failure, check cable.PXE- MOF: Exiting Broadcom PXE ROM.
  • Anonymous Mar 24, 2014
    stop 0x0000007 B (0XF78D2524,0XCOOOOO 34, 0X00000000, 0X00000000)
    President:
  • 3,278 Answers
Recommend reconnecting hard drive.
Posted on Jun 30, 2009
    Problem Solver:
  • 19 Answers
This is the PXE boot for the factory, or a tech to shoot windows into it. As the machine starts, press the key that will get you into the BIOS to make sure the hard drive is the first boot device. If the computer then comes up with "No Operating System Found" you will need to get it reloaded. You get a windows cd, go back into the BIOS, set the cd drive as first, then save and restart. Press any key when prompted, and follow instructions.
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
First a error message, then no reaction
Your computer seems to have problem locating your HDD. Or the other issue could be your boot drive selection on boot up. Try selecting your boot drive in CMOS setup by either pressing "del" key, "F12", "F2", or informed by your computer. This should take you to the CMOS setup. Find "Boot priority" and give your HDD the 1st choice. Also make sure the computer sees your HDD. This should be under "configuration". You also need to check you CMOS battery, this is a button cell on the mother board. If this battery run out of power the CMOS memory cannot be saved and go back to factory default, where the HDD is not known. Please make note of all the changes you have made, so that if you made changes which you shouldn't have, than you can trace back your steps and correct it. If the above suggestion shouldn't work you may need to consider changing the Mother Board. PXE boot is a network boot to explain generally. You need to have a network and a domain hosting your boot systems. If you want to know in detail go to this link http://www.howtogeek.com/57601/what-is-network-booting-pxe-and-how-can-you-use-it/ . Or don't bother reading geek information :). Let me know your outcome and Good Luck.
Problem with acer laptop. My laptop stopped booting after restart. I just moved my laptop from bed to floor . while in power on the program just crash not responding, then came a blue screen and said...
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. It looks like it is set to boot from a Network or LAN first. You want to boot from the hard drive 1st or the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Acer Computers & Internet
Windows is working normally and suddenly the ideapad Y430 shows a black screen and the following error messages: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C) 2000-2008 Broadcom Corporation Copyright...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 18, 2011 | Lenovo 3000 G530 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Apr 08, 2010 | Lenovo 3000 G530 Notebook
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 31, 2010 | Lenovo 3000 G530 Notebook
Media test failure, check cable
Video card failure replace your video card
Feb 10, 2009 | Lenovo ThinkPad T41 Notebook
Lenovo 3000 N500 Notebook Logo
462 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
