Question about Samsung LN37A530 37 in. LCD HDTV
NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE THE MUTE OFF. TRIED WATCHING DVD, WORKS FINE WITH SOUND, THEN BACK TO CABLE, NO-SOUND. PLEASE HELP! TV IS SAMSUNG
  • Anonymous Mar 19, 2014
    watched a dvd I don't have the remote now I only have snow
  • 304 Answers
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Posted on Jul 17, 2009
26LC7D-UB Can my LG remote be reprogramed to the TV?
If new batteries correctly installed do not revive your LG remote control, it probably is shot.
May 17, 2018 | LG Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
The sound will not work when watching the tv, but when watching a movie on the dvd player attached to the tv the sound works. My husband says he accidentally hit the directv remote and the sound was...
Without knowing the model of your remote or direct tv box it is impossible to answer that question other than to say, did you try unplugging the power from the box, waiting a minute or two and plugging it back in?
Jan 22, 2018 | Toshiba 32E200U 32 in. TV
We have a DVR hooked up to our 1989-99 Mitsubishi TV (floor model) still in amazing working condition. The remote control for that TV never allowed us to put the TV on mute. If the mute botton was...
Well, without knowing the exact model of tv and remote, I can just give my best guess.
Try using the volume up/down on the TV and / or the remote.
On the TV, try pressing both the volume up and down at the same time.
Stick the remote right in the face of the TV (direct in front of the remote sensor) and hit the mute button.
Try tapping the mute button in very short single bursts rather than pressing it for a half second like you would any other button.
If any of those work, please come back and reply with the model of the TV and remote, because someone somewhere probably has the same issue and would love to have it solved!
Feb 24, 2011 | Mitsubishi Televison & Video
I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Mar 11, 2010 | Onkyo TX-SR502 Receiver
Philips 21RF vardaan there is no sound but everything works fine
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
Panasonic TH-42px75u Audio went out
re program remote codes 018,016,007,049,067,074,076.
you have to take your remote settings to default
Sep 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Samsung LN37A530 37 in. LCD HDTV Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
