Breville Quick Touch Microwave Oven, BMO734 Logo
d
dave gregory Posted on Aug 12, 2014
Breville microwave door not shutting properly
Have to push the door and keep hold of it for it to work
Breville toaster oven start button
Try some electrical contact cleaner. Tip the machine on its back.
How To Fix Breville Toaster Oven Start Button: 2 Solutions
https://splaitor.com > How To
Feb 9, 2021 - If your Breville toaster oven board is warped, your oven Start button doesn't work properly. The most common problem is when you press the Start ...
More here
https://www.google.com/search?q=Breville+toaster+oven+start+button+replacement
Pushing button does not open the microwave door
If the button won't push in to open up the microwave door, one of the little ears that holds the button in place has broke off and is keeping the button from being depress.
1helpful
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Microwave Will not Run
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
You will need to remove the outer cover, then shut the door and then you can adjust the door latches.
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
[email protected]
http://www.microwavedisplay.com
2helpful
Microwave door
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
Top Breville Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Breville Microwave Oven Expert? Answer questions, earn points and help others
