Question about Gateway E-2000 Deluxe PC Desktop
Need to know the max amount of ram
I am upgrading the operating system to Windows XP and I need to know the max amount of ram that can go into a Gateway LP mini tower kad select 800. it currently has 64mb.
  • bcooper_new Jun 30, 2009
    Thank you that was very helpful - do you know the ram type I should purchase? trying to purchase from frys electronics need to be able to tell them the type I need
  • 11,896 Answers
You can put up to 4 gigs
Posted on Jun 30, 2009
  • 73 Answers
Gateway E Series uses PC-2100 type memory. However, I thought the maximum was 2GB.
My notebook is a HP G42-372LA, and I need to know which is the maximum frequency in the ram that I can put?
Maximum RAM supportedUse the table below to determine the amount of RAM memory that is supported on your HP notebook PC. Operating System Amount of RAM memory supported Windows XP 1-2 GB Windows 7 and Windows Vista 32-bit 2-4 GB (Only about 3 GB will be used by the operating system) Windows 7 and Windows Vista 64-bit Any amount of RAM is supported by the operating system.Ordering replacement RAM memory
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 11, 2011 | Computers & Internet
When i install Bios up date for MSI KT6 Delta MS-6590 to up grade my RAM to 3 GB i have Problem m My PC go to hill too slowly but i have 2400+ CPU ???? how can i solve my problem
Ram need to be installed in pairs. Windows XP only recognizes a max of 4GB ram 3.5 usable. Windows Vista 32bit only recognizes a max of 4GB ram as well as Windows 7 32bit. Vista/7 64bit can recognise a much larger amount of ram. Find out if your operating system is 32 or 64 bit and make sure you are using the right kind of ram for your system.
Mar 13, 2011 | MSI Microstar KT6 Delta (MS-6590)...
Can I increase RAM by using some hard drive space
No. XP already does this (simulating RAM on disk) with the swap file. You can override the system settings for swap file size but usually auto is okay. In any case, disks are horribly slow compared to RAM so you're far better off putting more physical RAM in. You'll see a very noticeable increase in speed if your system is currently swapping out a lot.
Feb 18, 2011 | Microsoft Windows XP Professional for PC
What type of ram can I add to my Compaq EVO 510 CMT and what is the max amount?
DDR SDRAM type Ram i.e. DDR1 with 266mhz speed with DDR266/PC2100 compliance. You can simply ask for DDR SDRAM 266Mhz or you can find online with the similar compliance, DDR266/PC2100 Compliance.
I hope you still have the old one which was installed on the system, if so look at the white sticker, it should be labelled there...
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Compaq Evo D510 Minitower (Open Box)...
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
Slow computer with 256 MB,
efore you make any purchases, you need to know how much memory you have and what type of memory to buy.Find out how much RAM your computer has:
Windows 7
Windows Vista
In Windows XP, go to the Start menu, click Settings, and then click Control Panel. Click System and then select the General tab. At the bottom of the page you should see the amount of RAM.
Most games will specify the minimum amount of RAM you need to install them and play. For example, Harry Potter And The Prisoner of Azkaban requires 256 MB. This amount includes RAM that the computer needs to do its own background work as well as to run the game.
The amount of RAM you need depends on the operating system you are using. For systems running Windows 7, Windows Vista, or Windows XP, you will need the minimum recommended amount, but more is often better, depending on your needs. If you just use your PC for surfing the Internet and writing letters, you need 512 MB to 1 GB. For more RAM-intensive programs, such as games or photo editing, or if you like to use a lot of applications at the same time, such as desktop publishing and video rendering, more than 1 GB is recommended. Each program should come with system requirements that show both the minimum RAM needed to run the program, and the amount of RAM needed for its best performance.
RAM modules can be purchased in a variety of sizes.
Figure out what type of RAM you requireTo determine the maximum amount of RAM your computer can handle as well as the speed, consult your PC's owner's manual, which should show you the number of slots (the place where you insert the RAM), how much each can take, and the maximum your system can use.
May 14, 2010 | IBM PC 300GL PC Desktop
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
Compaq EVO N1020V Not reporting RAM correctly
This sounds as thought he RAM is faulty.
You need to have installed 2 x 512 MB DDR 266 SoDIMMs and not 1 x SoDIMM.
If you have placed 1 x 1Gb SoDIMM in ther EVO this would account for you only seeing 480Mb of RAM.
Sep 24, 2009 | Computers & Internet
Need to know how much RAM system can handle
2GB max is the amount of RAM this machine can handle according to cnet reviews about the machine.
http://reviews.cnet.com/desktops/gateway-e-4000-series/4507-3118_7-20824814.html?tag=mncol;psum
May 24, 2009 | Computers & Internet
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Gateway E-2000 Deluxe PC Desktop Logo
441 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
