Question about Jenn-Air Ovens
Stove keep beeping when not in used. - Jenn-Air Ovens
  • Jenn-Air Master
  • 3,361 Answers
Replace the touch pad assembly.
Posted on Jun 30, 2009
  • steve
    steve Aug 05, 2009
    You may not like the answer, but it is the correct answer.
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Ovens
My wife used the self clean feature on our gas stove an now it keep beeping and showing the f3 code how do i make it stop cause the stove wont even turn on
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 22, 2010 | Ovens
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F4 comes up on my stove, keeps beeping what to do
Sorry to say you will need an engineer to check the heat sensors as they may be faulty
Sep 21, 2009 | GE Ovens
Temperature probe guide won't quit beeping
you have a bad computer board or clock assy. same thing the most common thing that cooks the board is heat and usually from self cleaning the oven,next time send the model number,if this is a slide in stove under the oven door is a drawer,open it and look at the frame,you'll see a tag with model and serial numbers,if that functions by itself you have a bad board.
Feb 07, 2018 | KitchenAid Ovens
Ovens Logo
60 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
