Question about Garden
Stanley hydroautomatic 17.5 HP lawn tractor wheel
I have a stanley hydroautomatic 17.5 HP lawn tractor with a right front wheel that is wobbling. I would like to have a parts diagram for the front axle/wheel assembly as I had some parts come off on the ground while I was mowing before the wheel started wobbling. I can't tell exactly what they would be but I think they were inside the wheel and around the axle. They appear to have been sheared off. Where could I get a parts diagram for stanley mowers? The model # under the hood is 425605X692.
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
SOURCE: Craftsman Model 917.276641.
Do you see a belt diagram posted on the deck somewhere? If you do follow it. One very important thing to remember with belts is the v-pulleys accept the v-portion of the belt and the flat pulleys accept the flat side of the belt. If I can be of more help please feel free to mail me.Donnyb60
Posted on Mar 18, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
What causes the front wheels to spread out making turning and steering impossible on a husqvarna lawn tractor.
the tie rod between the two wheels has broken or come off
the steering rod works on that rod or on one wheel which is connected to the other wheel by that tie rod.
Sep 04, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Looking for diagram on front end
Go Here:
Husqvarna YTH2348 96043005901 Riding Lawn Mower Parts
I have no connection with erepair but I buy parts from them all the time. good prices, excellent service. Great for the DIY.
Apr 16, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Front left wheel fell off of my Craftsman tractor. Model 917.274.650 I ordered new washers, bearing flange, etc. Now I discover that the flange won't fit into the hub of the wheel. The "shaft" hole...
go to sears parts .com and look up your model and the will give you a parts list and you can check if you have the right part they also have on line and phone help on any of their modfels.
Aug 15, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
770 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
