Question about Sony Playstation 3 (PS3) Console
Ps3 how do i re align the track
I have a ps3 and the ps3 will not spit out the game or read the game someone told me that i need to realign the track but did noot tell me how to do it how do i do this
  • 11,896 Answers
Pull tray completely out all the way, then hit eject button and it should **** it back in and align itself
Posted on Jun 30, 2009
How do you realign the cars steering wheel
this is a specialised job and requires a tracking gauge and plumb lines and lot of patience to re-align to ackermans principles .i assume that the spokes on the steering wheel are not in alignment so someone has tracked this vehicle without adjusting each arm equally resulting in this fault ,and if its not reset right then you will have 2 turns to the right and 1 and a half to the left or similar so it has to be done properly and not just the steering wheel taken off and turned a bit on the splines .
Feb 21, 2011 | 2005 Chevrolet Aveo
My ps3 wont read my discs
well try putting in a music cd ORIGINAL as the tracks are wider and easier for the laser to read.. if it reads it your laser is going bad or may need to be cleaned, if it doesnt read that either your laser may have failed all the way and it needs to be refurbished or repaired.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
My PS3 stopped reading my Blue ray movies and my PS3 games. only had it about a month. but i just came back from South Carolina and the night i returned i tried to play a movie for my wife and i but...
1 of two things might have happend your track might have jumped or
2 your laser might be gone it sucks i know but easy fix is a little costly as a laser will cost around 50 and the install will cost around 30 well thats what i charge if someone trys to get you to pay more i wouldnt
Mar 29, 2010 | Sony Playstation 3 (PS3) Console
My PS3 works fine, but the problem is that my PS3 won't load disks it only ejects. The only way I can load my disk is by turning it off and then turning it back on and then it starts loading my itself then...
The drive is out of alignment. Sometimes this can be fixed by pressing and holding the eject button for about 30-60 seconds. You will see the blue light start blinking and hear the drive gears moving. If this does not resolve the issue the blu-ray drive will need to be disassembled and the gears will need to be realigned. This is a very difficult procedure, even more so then replacing the blu-ray laser lens.
GATpro Repair performs this service.
Mar 05, 2010 | Sony Playstation 3 (PS3) Console
I moved my PS3 from one area to another area. When I hooked it back up the TV read that the PS3 was not turned off properly. My wife told me that she turned it off. But was incorrectly turned off...
Sounds like there is something loose inside of the dvd drive especially if it wasn't accepting discs before.
If you are savy enough, go inside of the ps3 and remove the dvd drive. Then unscrew the screws to the dvd drive, when you open it up there will be a white plastic piece on top that holds the dvds in place so the drive can read it, this piece might just need to be realigned properly.
If its not that then check to see if there is any loose debris in there and remove it, then put the screws back on the drive, hook it back up to the ps3 then put the top cover back and try the drive again. Should be okay at this point.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont read games
the lens eye maybe dirty clean it rubbing alcohol on a Q-tip. gently clean the eye and use the other end of the Q-tip to dry the access rubbing alcohol.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
CD player won't read CD's!
I've been told CD players in cars need periodic "blowing out" to remove dust and debris. I would see if someone could do that for you, and you could try the cd head cleaner too.
Nov 13, 2008 | 2001 Saturn SL
PS3 Blu-Ray Drive Track Assembly
Open the console and remove the disc drive (1 ribbon cable and the power cable). Flip it on the part with the board and remove the 3 screws at the bottom and the 2 one at the top. Remove the cover Remove the 5 screws and open the drive like a book. As you have the drive laid down . carefully remove the guiding mechanism(1 screw) on the left side of the laser deck there is a plastic rail that rests on a small plastic wheel. Push back that rail as far as you can until it clears the gears located on the wheel (you should notice a slight lowering of the laser deck). Carefully put back the parts and before you put the cover hook it to the console and try. Hope this will solve your issue.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't read game discs or DVDs
no mate u need 2 send your ps3 back 2 sony this happened 2 me mate they havent got a solution 4 it they believe that the blu ray laser has burnt out meens you play 2 much lol
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
124 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
