Question about Kenmore Elite 45986 Front Load Washer
It wont star washing , it shows dl and then an f after stars beep beep
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Washer wont star and shows me a code dl f how do i fix that?
FdL means there's communication problems between the main circuit board (CCU board) and the door lock. Most often the problem is on the CCU board. There are bad solder joints (also called cold solder joints) causing hit or miss communications between the CCU and the door lock. The fix is to remove the CCU in the case (inside machine, top, back, plastic case) then remove the CCU board. You'll want to touch-up the solder joints on the relays (5 of them) and the spade connectors (all these joints are the largest ones on the board) If you're not up on your soldering techniques you can take the CCU to a good appliance repair shop and they should be able to help you out. Good luck.
Mar 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
Whirpool door latch--digital display show DL.. how to fix it..and how much it cost to fix it
Hello there
This is telling you that the door latch assy may be bad
first remove the bottom panel. you will have to use a star type driver to get it off than reach up and manually release the door this is a 65 dollar part and your local appliance repair center should have oit or go to applianceparts pros.com and they have them their ok
Hope this very helpful for you
Best regards Michael
Jan 19, 2010 | Kenmore 4292x Front Load Washer
My washer is not washing, is displays the letter F. What so I do?
my washing machine is not washing, and the buttons- intensive, rinse hold, pre wash and dry even the pause and star will not work but the pause/star light will be showing.
Oct 10, 2009 | Kenmore Elite 45986 Front Load Washer
Looking for windows xp driver for star sp200 printer please send me a link to driver download at ryoungland@aol.com
This printer is only support to windows 98 and windows 2000. here is the link where you can get the driver for your printer. hopefully it will work.
http://www.barcodesinc.com/star/sp200-series-drivers.htm
Aug 28, 2009 | Star Manufacturing Star SP200 Series...
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
I wash my 1994 grand cherokee wont star
check distributor is not wet or battery is not low.. as a result of shorty in spark plugs.good luck.
May 31, 2008 | 1994 Jeep Grand Cherokee
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
