Question about Magellan Maestro 4250 GPS
Lost fuse to Magellan 4250 and cannot find another for sale
I called Magellan and the fuse is:
5.2 X 20m Fast Acting Tube, 2 amps with 250 volts maximum. However, I cannot find one anywhere.
Buy another 4250, take the fuse and return to Magellan, is the only answer I have found or buy a new A/C Adapter, which cost $29.95.
I had a similar problem with a Mag. Maestro 4040. I searched high and low for the 4.6 x 16mm fast acting tube fuse 2a 250v. I called Magellan and they would not sell me or tell me where to find this fuse. Needless to say, I found it for $1 at Wayne Electronics in Wayne, NJ. Call them to see if they have the fuse you are looking for.
Posted on Nov 30, 2009
Did you check RadioShack website? it is available for $2.99 for a 4 pack.
Posted on Nov 15, 2009
Where do I find a fuse for a wheelchair charger. It is a glass tube fuse approc 3/4 " long and has teh # F10AL250AP on it. I know its a fast acting 10 am , 250 Volt fuse, but i can't find one that is...
Hi. I have a box full here in New Zealand. I get them from a local electronics hobby shop called Jaycar electronics.
Try any office equipement servicing outlets in your area.
Try E-bay. Try googling "electronic components", and see what you find.
If still no luck, send me an email,
scooterworks@xnet.co.nz
Good luck. Neil.
Jun 17, 2010 | Pride Mobility Products New Pride Mobility...
I have Amana Radar Range microwave. The repair guy was just here (fixing my real stove) and told me to change fuse to ''20 amp 250 volt fast acting ceramic fuse.'' Where is the fuse on this microwave?
first unplug your microwave and let sit for awhile to drain any stored energy that may zap you. then, if it is an "otr" there are 2 screws in the vent slats on top that you remove. once removed, you lift up on the control panel and it tilts out. voila! there is your fuse. pop it out and pop in a new one. ceramic 20 amp is correct. check your old fuse to be sure it is 20, not 15 though.
Aug 26, 2009 | Microwave Ovens
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
I need to replace the external fuse on a marantz Model 32 amp.
Well, take good look at the Fuse itself on metal area.
If it says AGC, then fast acting.
If it says MDL, then Slow Acting.
If you cannot figure it out, then just use Fast Acting since it is more commonly used in smaller Receivers and Amplifiers and Fast Acting will cutoff faster (compair to Slow Acting) if there is any unknown Prblem with Chassis.
Jan 31, 2009 | Audio Players & Recorders
Magellan Roadmate 760
The cord for the roadmate 760 takes a 3 amp 250 volt fast blow fuse.
Feb 09, 2008 | Magellan Roadmate 760 GPS Receiver
Projector Problems
Sounds like the fuse popped. t5a=5 amps 250v=250 volts So you will need a fast-acting 5 amp 250 volt fuse
Mar 14, 2007 | InFocus ScreenPlay 4805 Multimedia...
Magellan Maestro 4250 GPS Logo
680 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
