Question about SanDisk Sansa m230 MP3 Player
ITunes will not recognize my SanDisk Sansa m230
  • 93 Answers
Well it will not really recognize your player. cause its only compatible with wondows media players
Posted on Aug 16, 2009
  • 341 Answers
Sorry, iTunes does not support any non-iPod devices. However you can use something called Double Twist, it's a program that pulls iTunes music from your library and automatically converts the files to the necessary format, also it's really easy to use, and it has an interface just like iTunes.
Hope this helps!
Posted on Aug 25, 2009
SOURCE: pb for my sandisk m230 mp3 player
Same thing happened to me... try this...
1) disconnect all cables
2) turn power on (hold menu button until screen lights up)
3) Press "menu"
4) scroll down to "settings"
5) scroll down to "USB"
6) select "MSC" (default is probably auto detect - which I think there's a conflict with)
7) turn power off (holding the menu button down)
8) connect USB to computer and hopefully start loading files
I bought 2 of the 512 models, one didn't work... so I took it back and had to buy a 2gig model... got home and it didn't work! I tried the above for the new one and at least the computer recognizes it! Everything seems to work fine...for now...
Posted on Dec 13, 2007
  • 758 Answers
SOURCE: SanDisk Sansa m230
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
Posted on Mar 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: SanDisk Initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
  • 102366 Answers
SOURCE: pls driver for sansa sandisk m230 model
You can download the driver from the manufacturer's web site at http://www.sansa.com
Posted on Apr 07, 2010
  • 102366 Answers
SOURCE: will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Posted on Apr 29, 2010
SanDisk Sansa M230 Problem:When connected to my PC and try to open system says " this device is not formatted. Do you want to format it now?" . If "yes" is selected then system says it...
Connect your SanDisk Sansa M230 to your computer again. Ignore the format message and go to My computer icon on your computer, right click on the drive (E:or F: or G: etc) representing your SanDisk Sansa M230, scroll to format allow it format from there.
If it still refuses to format, you can the reset the SanDisk Sansa M230and try again.
In case you don't know how to reset your SanDisk Sansa M230, read the info on the below link on how to reset your SanDisk Sansa M23;
http://www.fixya.com/support/r6977146-reset_different_models_version_san_disk
I hope this helps.
Good luck.
Feb 22, 2011 | SanDisk Sansa m230 MP3 Player
Pls driver for sansa sandisk m230 model
Apr 07, 2010 | SanDisk Sansa m230 MP3 Player
I cannot add music from from my itunes library to my Sansa m230?
itunes puts drm on music get that off and your f ree to go
Sep 26, 2008 | SanDisk Sansa m230 MP3 Player
Sansa clip problems with driver
okay
there u go
rate me fix ya
choose the model of sansa thta u got
http://www.sandisk.com/sansa/#/support-0/
Aug 08, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
Yes it is...You will have to buy the songs from itunes and then you can use windows media player to transfer them to your device...
Jun 29, 2008 | SanDisk Sansa m230 MP3 Player
Very new to this-got iPod, can I put songs on SanDisk?
I bought a sandisk and it came with best buy stuff loaded. Well best buy stuff expired and i have a lot of memory tied uop with it. I want to totaly reformat and remove all related stuff to best buy so I can start from scratch
Apr 10, 2008 | SanDisk Sansa m230 MP3 Player
Sansa M230 not seen in Explorer or Windows Media Player
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
Mar 23, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230
How did you transfer the music? If they are not viewable on the device, you might try updating the firmware. Otherwise, I would format the device and drag and drop the files manually thru My Computer. * format - right click on the device in My Computer, and select format
Sep 10, 2007 | SanDisk Sansa m230 MP3 Player
MWP does not recognize my san disk m230
i suggest an update software ,this will solve the problem.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk sansa m230 MP3
Windows Media Player would have worked
Aug 29, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
361 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
