Question about Whirlpool GZ5730XR Kitchen Hood
Ventahood b100: need wiring diagram
I just took apart the light/fan wiring box for the ventahood b100. Forgot to take a picture! It's got two switches, a transformer, a condenser, and the two light connections. Three wires come to this box: red, white and black. Not sure how to connect everything back together. Help?
5 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: Parts left over after replacing element!
here is a link to pictures of the assemblies. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=GJP84902&pop=flush Eric
Posted on Sep 15, 2009
Testimonial: "Thanks!"
charleshucke
  • 1114 Answers
SOURCE: I just took apart the light/fan wiring box for the
White and red are hot, and the black is the ground wire.
Posted on Mar 12, 2011
  • 2006 Answers
SOURCE: On my GS563LXSB- repair person
http://www.ajmadison.com/ajmadison/itemdocs/GS563LXS_ii.pdf
The installation instructions say a 120V 15 amp circuit, so I don't know what the repair tech is recommending! It is most likely that he hasn't a clue on what the problem could be and is grasping at straws.
It would depend on how the igniters act but they might want to check: http://www.searspartsdirect.com/partsdirect/part-number/Whirlpool-Parts/Range-Parts/9758080/0022/664/Model-GS563LXSB1/1198/0124002?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=W0801053&diagramPageId=00005&productTypeId=x&searchModelNumber=GS563LXSB1&subCompDesc=Control%20panel%20parts&brandDesc=WHIRLPOOL&modelDesc=FREE-STANDING-GAS-RANGE&blt=11
Posted on Aug 02, 2011
SOURCE: changing from a 3 prong to a 4 prong power cord
green wire is ground, so there is a spot by where the wires go into the range, with a screw on it that may be green, and the green wire attaches to that. it may say earth by it as well and have a symbol that looks like a 3 lined arrow pointing down.
Posted on Aug 30, 2011
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
Ceiling fan 3 way switch install
The black is the hot wire, the white is natural and the black/white wire is for the light option.
Jul 02, 2013 | Dryers
Need to see if evap fans r working
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Jul 06, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Ventahood fire suppression systems
the wiring has to go to the microswitches
you can add up to three micro switches,they are located in the control box
there colors should be bl,brown and red
look for nc or no(you can depress the switch by hand to see when you press itup it shuts power
it has to be repeated for the light,plugs and make-up air
to pass inspection when you press up on switches the have to shut off electric lights and make up air
you dont need a relay.
the basic system is a contactor line and load runs exhaust and make up air power in power out.
you need power just for the contactor to pull in.
you need to add a switch break hot on contactor power
Jul 02, 2008 | Kitchen Ranges
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Whirlpool GZ5730XR Kitchen Hood Logo
795 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
