Question about McCulloch Garden
How do I adjust to chain tension on my Mac 3200?
  • 2,176 Answers
When I service one I clean all the debris out of the covers and the rail in the bar. Then reinstall all parts with the chain a little loose. Using a pair of gloves have the hex nut on the cover loose enough so you can raise the tip of the bar, while doing this use your screwdriver to adjust the screw so that when you lift up on the chain just the bottom of the teeth are about exposed. (drive section) still holding on the bar snug the hex nut and again lift the chain, after doing this pull the chain bu hand (with gloves on) to make sure it rolls freely and I always recheck a third time and then tighten the nut fully and go cut some wood
Posted on Jul 01, 2009
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
How many drive links does the MAC 3200 14" chain
A good saw shop will be able to set you up with the correct chain.
Apr 09, 2013 | Garden
My chain can off my mac 3200
There should be two nuts on the main body of the saw just near where the chain bar enters the main body. Loosen them, slide the bar into the body, adjust the chain as needed, pull the bar out a bit to tighten the chain onto the bar, then tighten the nuts. You are good to go. Good luck. Please rate me.
Jun 18, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an older McCulloch chain saw- Pro Mac 610. When using the saw the chain will get very tight. If I adjust the chain to the proper tension, make a couple of cuts the chain loosens and must be...
The main reason for a chain to tighten is because it is not getting enough oil to the bar, or too thin an oil is being used, you should see a good spray of oil off the end of the bar when held against a tree stump, if not try adjusting the flow if it has an adjuster.
Apr 01, 2011 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
I have an old mac 110. I believe I need the chain tension adjuster as I am not seeing how to tighten the chain. I can't find my manual so I don't have a part list.
Loosen 2 nuts that are on middle of inside end of bar closest to motor, on retaining plate. Dig out shavings & dirt on outside of that plate there is a recess hole. In it is a adjustment screw to tighten chain. Screw in till it takes up the slack in chain. Retighten 2 nuts when finished.
Jun 30, 2010 | McCulloch Garden
Want to purchase bolt to adjust the chain on my mac 3200 Chainsaw
You local Mower Shop should be able to help you, he can order one for you
Jun 16, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to locate chain & bar oiler adjustment screw for mac 3200 chain saw
Look to the lower left side of the bar (as you hold the saw normally)--there should be a screw head in the engine case there. Check the adjustment by holding the bar tip at speed near a piece of cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
May 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Re-install chain
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Look carefully at the picture and your chain, it can be mounted backward; they do not cut when backward.
Dec 04, 2009 | McCulloch Garden
How do i change the chain on my mac 3200
remove the 2 nuts holding the cover on, then back off the set screw remove and repl chain, install cover snug,then adjust chain tension ,tighten nuts
Aug 11, 2009 | Garden
Garden Logo
1,009 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
