Question about Electrolux Epic 6500 Vacuum
No contact with electricity Won't start - Electrolux Epic 6500 Vacuum
    Problem Solver:
  • 11 Answers
See if the wier are good
Posted on Oct 01, 2009
Vacuum stopped working. I think it overheated and I cleaned it out really well. Still won’t start
These days many electrical appliances are protected by a thermal fuse or breaker so overheating will cause the circuit to be broken. The thermal breaker should in theory reset itself when the motor cools but that isn't always the case in practice. The thermal fuse needs replacing when it "blows".
It might be by complete coincidence something completely different but the only way to discover the fault is to dismantle the cleaner and check the circuit with a multimeter.
Mar 03, 2018 | Vacuums
Electric cable won't retract
try this link it's not the same model but it may help you on hoe to get to the cable sounds like the spring as broke or come adrift
http://www.sannerud.com/house/miele.html
Aug 21, 2012 | Vacuums
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
Start button is flashing and won't run
Hi Kathleen,
I'm sorry to hear you're having difficulties with your DC28. We'd appreciate the opportunity to run through some troubleshooting with you over the phone to help resolve this issue. You can call us on 1-866-693-9766 - or if you'd prefer, email your contact details to askdysonUS@dyson.com, and someone will be in touch as soon as possible to help.
We'll look forward to hearing from you.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Mar 03, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson dc04 not starting
I'm sorry to hear you're having difficulty with your DC04. If the machine won't start at all, it's best if you contact us directly so we can run through some troubleshooting over the phone, and provide further assistance. You can call us free on 0800 298 0298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dec 19, 2011 | Vacuums
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
My Panasonic performance plus platinum vacuum cuts off and on while using the beater bar, this doesn't happen at all using the stair cleaning attachment. It appear electrical contact is being lost where...
The solution to my problem which is located at the lower electrical plug on the long wand was to expermint using a nickel and placing this in an area where the long wand connects with the beater bar section, here there is a gap which allows too much clearance thus losing electrical contact at times and then making contact. A nickel is about .075 thousands thick so I hacksawed a flat piece of metal that was this same thickness, the other dimensions of this little piece are 3/8 inch wide by 5/8 in length, I then forced this little piece in the above mentioned gap which places tension maintaining electrical contact. It works fine now, there is either wear in the electrical contacts plug in, a new lower electrical plug in line will fix this but I can order one later I need to vacuum the whole house so now I can. Jon Olinger
Jul 09, 2008 | Panasonic Vacuums
Broken belt, motor wont turn
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=721048
Generic problem for all Vacuums
Broken belt, motor won’t turn
Posted by msmclovin on Jun 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the motor shaft won’t turn then you may have a bad motor or a stick carbon brush, but if it is just the belt the replace the belt with a genuine belt because the average belt change id every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator. But you question does not tell me what brand name and model # it is so I have a hard time to diagnose the problem for you so my explanation if just a generic one and should work for you but next time please note the brand name and model #. If you have further problems please feel free to contact your local vacuum cleaner dealer in your area or call the Kirby cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
Hoover model F8515 won' t **** up any water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
Hoover Model F8515 won' t **** up any water
posted by kevingao92 on Jun 24, 2008
It could be in reverse do you have any tips
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
26 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
