Question about Microsoft Xbox 360 Console
Same thing i keep getting fuzz and green lines across screen i think it is the av slot that burns out in internally should probably send in to get it fixed or get a new one?
  • Rod Sims
    Rod Sims May 11, 2010
    Has the unit been propley Xclamp moded yet?
    Novelist:
  • 168 Answers
This i have seen before and it tells me the machines is displaying the signs of lead free solder failure (85%sure). you could strip the machine down and replacing the x-clamps at the same time do the heatgun fix if you dont have access to an IR oven.
To me it will just get worse and will definately need the x-clamps replacing AND the solder re-seating.
I dont think it would be the av slot itself, a way to try is if you got a hdmi cable try that. but it is more than likely a solder issue and will get worse. if its under warranty send it back.
hope that helps in some way
Linda
www.xboxrepairkit.co.uk
Posted on Sep 28, 2009
Why my canon G12 present black display or horizontal lines overexposed?
It's common on the G12. This is the place fixing these: www.CamerasAndParts.com They have a specific service package for this $89, parts and labor come included, plus they do the internal fix so it doesn't keep occurring on the camera. They are the best place for help with the Canon Powershots. Best of luck with it.
Jul 25, 2014 | Canon Powershot G12 10mp 5x Digital Camera...
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
My dvd player is plugged in, but it won't even turn on, The AV thing has part of a plug stuck in it that broke off and is stuck inside and won't come out- think this might have something to do with it,...
You should contact the company that made your dvd player and tell them your problem. they will probably send someone over. IF you have a receipt they may either fix your DVD player or give you another one.
Apr 11, 2010 | Insignia I-PD720 Portable DVD Player
A fuzz sound is coming across my speakers. How
Try and isolate the problem by disconnecting all components and reconnect them one by one. Fuzz could be comming from one particular component, or could be an internal fault in the bose amp.
Jan 14, 2010 | Bose (321GS) System
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Marshall mg100hdfx loud fuzz and distortion and no guitar sound
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Jun 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
My 360 keeps burning up av cables.I have bought three already .Evertime i plug up a new one it works for about ten mins.then my screen will go all blue or all green. What should i do my warnty expired...
Thats hard to tell I can be many things from GPU overheating or damaged, to a bad connection on the board that sends the signal out to the TV. The only way is if you can open your xbox by yourself and check for any burn circuits or checking the GPU and the heatsink, and check if it has the thermal compound on it also.
Aug 22, 2008 | Microsoft Xbox 360 Console
Skipped printing
I think you should be able to access the strip that is probably causing the problem.
Most all of these machines use a Mylar tape with extremely fine vertical lines to keep track of where they are going; the thin lines are interpreted by photo-optics and the printer counts lines to control its position.
The strip runs completely across the width of the printer and the sensor is located in the carriage.
With the printer turned off, open the section you use to replace the cartridges and with a flashlight peer inside to locate the strip.
It is probably contaminated with dust or some wayward ink.
Use a paper towel that doesn't produce fuzz or 'micro-fabric' and spray a little wndow cleaner onto the cloth - NOT in the printer.
Gently pinch the strip between your cloth-covered fingers and travel back and forth a couple of times.
Check the towel/cloth to see if in fact some grubby stuff is on it.
If so, you are probably back in business.
If not, you may have some fuzz trapped in the track the strip runs in.
To access this slot, you will have to BS the printer by opening the machine with the power on this time, VERY carefully draw a clean paper towel (non-fuzzy again, don't want more lint inside) along the Mylar strip and through the slot in the carriage in which it rides.
With both of these accomplished, your machine shouldn't get lost on its trips back and forth.
Aug 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
Microsoft Xbox 360 Console Logo
82 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
