Conair TAD 2014 Answering Machine Logo
Posted on Nov 08, 2007
Conair digital answering system
Where can I find a manual for this model answering machine
  • Anonymous Nov 21, 2007
    Looking for an pdf manual for my TAD 2014 answer machine.
    Can NOT figure out how to delete messages & why the digits of received messages is in continual blink mode! Why is there no manual to download?!
  • Anonymous Apr 18, 2008
    How to use remote access feature for TAD 2014
    How to use time and date stamp for TAD 2014
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
956
Points
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Anonymous
Level 1:
  • Posted on Apr 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
956
Points
I found a blog that had the answers to most of the issues regarding setting the time and date along with other useful information.
Go to this link to get the information http://tad2014.blogspot.com/
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Sep 16, 2009
SOURCE: conair tad2018cg digital answering system. Would
hello,
Here is the link to your manual
http://www.conairphone.com/IBs/digital_answering_systems/tad2018.pdf
Hope it helps
Flashing L on display conair TAD 1216PWT answering machine
i was wondering the same thing. i contacted conair, and although they no longer make these things, a very nice lady named maria was able to find an owners manual which she promptly sent me via email. the L means the 4 triple A batteries need to be replaced. hope this helps.
Need User Manual
well you can please follow the below link to get your manual -
http://phone.manualsonline.com/manuals/mfg/conair/tad2018.html
(click on the get this manual button to download the manual)
Good Luck!!
Remote operation
Here it is.
To erase messages.
I lost my manual for TAD 1212. I cannot access my
Check this link and select the product:
http://personalcare.owneriq.net/manuals/mfg/conair/conair_product_list.html
Have a good one!
Conair callkeeper tf0803 instructions
conair digital answering system t0901...how do i set the number of rings on the machine? It is picking up with no ring, and cutting off before a message can be left.
Conair Call Keeper TAD920
How do you work the remote answering from a different location...
Top Conair Lands Phones Experts
k24674
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
