Question about LucasArts Entertainment Company Lego Indiana Jones: The Original Adventures for DS
Chapter 1 level 3 getting across from one bldg to another
My son is trying to get across a post connected to a string with a gray square by it to try to get something on a different building. Any ideas how this is done so he can continue on?
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Here is a walkthrought ope it helps
http://www.gamefaqs.com/portable/ds/file/944571/53540
Posted on Jul 06, 2009
Detailed info research on my truck has me ? This; ht clearance on a 2004 ford explorer is 72.1 inches/ 6ft 1 in. I have the optional load
If it is an option, you need to measure the height yourself. Pull it into the garage, you need three people. One on the right and one on the left with a piece of string. They hold the string across the top of the vehicle to the wall on each side. The third person stands at the back to ensure that the string is level. When it is level that third person measure the height one the wall of the string from the ground.
Apr 22, 2018 | Ford Cars & Trucks
I got a 1989 big bear it pulls to the right i put new tie rid ends and upper and lower balk joints in pulled cv axel it seems to be ok steering bearings seem fine also anyine have any ideas
Try aiming the handle bar straight and pull some kite string across the rear wheel , lightly touching the sidewalls of the tire. With the length of the string pulled across the front tire, adjust the outer tie rod so as to make front tire lightly touch the string. That should square the front tire to the back tire. Once the front and rear are squared, adjust tie rod in 1 turn for a slight negative toe. Do both sides while making sure to keep the handle bar straight during string and adjustment. That should help.
May 25, 2017 | Cars & Trucks
Will not drill straight.
It is my pleasure to guide you.
1. Check the straightness of the drill.
a. lay the drill on a flat surface and roll the drill across the surface. You can tell if the drill is bent.
2. Is the drill chucked off center? That is easy to do when you put the drill into the chuck and tighten the chuck. Sometimes the drill shaft will get caught in the check grippers out of center.
3. Make sure the drill head and or table is not at the 0 degrees the way they should be.
a. This can be done with a small T-Square. Put a drill that you know is straight into the chuck. Put the T-Square on the table against the drill. You should be able to tell if the drill chuck is out of square. If you have a straight edge that has a level bubble you will be able to tell easier.
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Delta 15 - 127 Drill Presses
Well i can never get a clean sound out of my BC RICH Warbeast NJ Deluxe, i'm assuming it's the bridge but i don't know how to stop it. The buzz gets into every tone i play, need ways to fix this issue,...
The Warbeast is notorious for having buzz problems, and the major cause is usually the bridge. What you can do is:
Standard B.C. Rich String-through bridge - There are two posts, one on either side, that are slotted for a flat-head screwdriver. It is NOT recommended that you try to adjust this with strings on the guitar! Turn the posts counter-clockwise to raise the bridge height. Be sure to turn them the same amount, to keep the string height in relation to each other the same.
Floyd Rose Licensed Tremolo - You will have to adjust the springs behind the tremolo to bring the bridge up slightly above level. You have to have the strings on the guitar to do this To do this, remove the spring cover on the back of the guitar. A phillips-head screwdriver is needed. There should be two screws, one at each end of the spring keeper. Turn them counter clockwise by 1/4 turn each time, following these steps:
1. Turn a single 1/4 turn
2. Tune the guitar.
3. Check for buzz.
If the buzz is still present, repeat steps 1 - 3.
I could not find any other bridge that came with this guitar, so one of these two options should help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Dec 26, 2010 | B.C. Rich Wmd Warbeast Electric Guitar
How can i unlock all characters in dbz shin budokai another road?
Hello bambamverall
Go throughout story mode (Another Road), to unlock the following characters:
Vegeta (Majin) - Get ending A (can be obtained y not letting enemies destroy any cities in the last chapter).
Picolo (fuse with Kami) - Beat him at the alternate path of chapter 3.
Bardock - Beat him as Goku in chapter 5.
Super Buu with Gotenks absorbed - Finish the 2nd level of chapter 7.
Super Buu with Gohan absorbed - Finish the 3rd level of chapter 7.
Future Gohan - Finish chapter 5.
Dabura - Beat him in the 2nd level in chapter 2.
Cooler (final form) - Complete the 2nd mission in chapter 4.
Hope this helps, good luck!
ajblaj
Sep 10, 2010 | Sony PlayStation Portable (PSP) Console
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Undo White Balance Sony F707
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
LucasArts Entertainment Company Lego Indiana Jones: The Original Adventures for DS Logo
103 people viewed this question
Top LucasArts Entertainment Company Video Game Consoles & Games Experts
seanwalters1
Level 1 Expert
Scott Alvarez
Scott Alvarez
Level 1 Expert
Stephen Roepke
Stephen Roepke
Level 1 Expert
Are you a LucasArts Entertainment Company Video Game Console and Game Expert? Answer questions, earn points and help others
