Question about Digi MAXX tal Media Explorer I Car GPS Receiver
The lock sign is stuck on the screen of our explorer 1 and the navigation feature wont work. radio shack said it needed a seperate card to operate. is this true or is there something else?
    Problem Solver:
  • 5 Answers
After resetting the unit 30-30 (Press the Reset button with the Power on for 30 seconds and keeping the button pressed Turn the Power OFF for 30 seconds) with the mapping SD card out of the system, it should then take the information from the SD card correctly. Recommend using updateable iGO or AMIGO program in the unit.. Works Great..
Posted on Sep 09, 2010
I have a TRC 502A CB radio that hasn't been used in about 5 yrs. I recently tried to use it and when I transmitted, the audio came thru the speaker. Any idea what's wrong?
it could be grounded inside...Somebody may had it set for Talkback features.. Take it apart look for speaker wires (see if soldered to resistors) if its shorted seperate wires ..just have speakers wires attached. Try external SPKR. Try different mics or radio may have gone bad completely.
Apr 07, 2011 | Radio Shack TRC-503 CB Radio
I went to Radio Shack to have some memory put into my phone. The employee placed it in and gave it back to me. When I got home, my phone was off. I tried to turn it on and nothing happened. I'm having a...
I'm sure the people at radio shack did it right.
Alot of times memory/SD Cards won't exactly show up on the screen or tell you their working.
Most phones can handle them without saying anything.
However.
Using a memory card
You can save, move and delete the files
between your phone and external memory
card. You can also move and copy the files
to computer from your phone.
To copy a file to the memory card
1. Select the file > Options > Copy to
External Memory.
2. To copy the file back to the phone, press
Options > Copy to Phone.
To move a file to the memory card
1. Select the file > Options > Move to
External Memory.
2. To move the file back to the phone,
press Options > Move to Phone.
To delete a file from the memory card
1. Select the file from the card > Options
> Delete.
In Advanced Mode, you have access to all
of the features of Breeze II including the
features provided by Breeze Mode.
To move the file from the card to the
computer
1. Connect the data cable with mobile and
the computer.
2. Press Menu > Settings >
Connectivity.
3. Press Select USB Mode.
4. Select Music Player, Mass Storage or
Ask on Connection.
5. Follow the instructions on your
computer screen.
note: Select Music Player when you want to
add music to the playlist in your device. When
you select Ask on Connection, it will ask you to
select either the Music Player or Mass Storage
every time you connect your device with your
computer.
Resetting a memory card
1. Press Menu > Settings > Reset.
2. Enter the password > External
Memory Reset.
note: The default password is '1234'.
Mar 29, 2011 | Pantech breEZeTM Cellular Phone
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Touchscreen wont work
touch screen wont work,
what is it doing ?
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
Police scanner stuck on one frequency, it won't scan automatically, but will manually, can you help me???? The scanner is only a year old. It's radio shack.
Is the squelch turned to where there's no noise when there is no transmission being heard on the radio? Also make sure that all the channels haven't gotten locked out. If they are, you should see something like L/O on the screen.
Mar 04, 2009 | Radio Shack Pro-2055 Base Scanner
1998 FORD EXPLORER REAR HATCH WONT LOCK WITH FOB / KEY OR SWITCH
We had the same problem with our 99 explorer there could be two seperate problems , problem # 1lock mechinism is very dirty from road dirt, take inside panel off and clean than spray with lubricant, problem # 2 bad lock actuator needs replacement ! good luck!!!!!
Jan 28, 2009 | 1998 Ford Explorer
Memory card is locked and I cant unlock it
Theirs a sliding piece on the card slide it to unlock if it wont work then get a new card the 2 gig ones are like 12 bucks at radio shack
Nov 29, 2008 | HP Photosmart R727 Digital Camera
Navigation on my Maxx digital explorer 1 has frozzen up.
I managed to fix my parents one by removing the memory card and blowing on the contacts then re-inserting the card I guess somehow the card must have dislodged and the map files could not be loaded this should work for you as the system needs the maps files in order to operate the navagation mode...
Hope this helps
Jason
Apr 20, 2008 | GPS
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Digi MAXX tal Media Explorer I Car GPS Receiver Logo
188 people viewed this question
Top Digi GPS Experts
Will Halftowaite
Are you a Digi GPS Expert? Answer questions, earn points and help others
