Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi TV rear projection (Model ?)
I would like to remove the screen and cleam the lamp lenses. Note on bottom of screen says. "Remove relay connector before removing screen so relay connector will not enter rear of screen" How does one do that? Don't see any connectors or wires in speaker area.
    Genius:
  • 1,694 Answers
No worries = generic note applies to more than one model....
Note:Use no cleaner on screen / lens caps = dry soft cloth....T.
Posted on Nov 10, 2007
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Relay Connector on Mitsubishi TV
IF IT IS A WS-55511 what you are reading is with the speaker grill removed--there will be one or two sets of wires coming from the front keyboard--before you remove the entire screen assembly you need to follow them to the right and unplug both plugs.
The screen assembly will have about 5 screws at the bottom edge--with both plugs free and the screws removed you pull up and lift the screen about 4 inches and pull it off--if you have questions ask before you attempt to remove the screen unit--tell me also why you want to remove it.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 12, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Have black dust looking spots on my screen.
Howdy;
Yes there is a way. The easiest for you would be to remove the back top of the TV. That will give acess to opt lense and mirror. But first check the Lamp and inspect the lense that the Lamp into. It does not take a lot to cause your concern. Use super soft cloth and wipe surfaces.
Good Luck,Big Irish.
Nov 22, 2009 | JVC HD-56G886 56" Rear Projection HDTV
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Glare-can we remove plasting sheeting on screen?
yes, you need a philips screwdriver, pull the speaker grill off, remove the 4 or 5 screws along the bottom of the screen assembly, unlock the 2 electrical plugs and remove them from their ties, lift up on the screen assembly and remove it. turn it upside down and remove the 4 screws holding the bottom of the frame on, remove frame bottom, slide screen protector out, re-assemble, bingo, no glare.
Sep 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Jan 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 55'' rear projection 1080i hd tv lense cleaning
Pry off the lower speaker grill... Remove the screws at the lower edge of the screen framing and lift screen frame of the two catches at the top. Be careful, there will be wires still attached to the front button panel... Then lay the screen down and support the bottom of it in some way because the button panel wires won't reach all the way... then using windex and papertowel cleam the mirror and lens(s) on each of the crts. Also clean the back or inside of the screen area and reverse the process to re-mount the screen.
Bill
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Lamp replacement
on the front of your tv, remove the front black cover on bottom under this you will see the lamp cover. remove this then the lamp.
Nov 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
Nov 04, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
