Question about Samsung CLX-2160N All-In-One Printer
Samsung Laser 2160 - White banding down left hand side only
The problem I have would appear very similar to those noted earlier. The white almost blurry vertical banding mysteriously disappears for a couple of sheets then returns. I've changed toner cartridge and waste toner collection but I'm loathe to spend £120 on the drum unit in case this didn't correct the fault. Has anyone contacted Samsung direct for their opinion and advice . I bought the printer from CCL in November 08 for a great price - (£142 + Vat) so it's out of warranty and I do feel a bit cheated. If anyone can help that will be great but if not I'm thinking about stepping uo to a Xerox (phaser) who have been at this game a good bit longer than Samsung.
  • 2 more comments
  • garrymgrant Jul 05, 2009
    Please clarify the problem you posted on FixYa.com
    Thanks for getting back and sorry for my delay in
    getting back to you. Yes you are right regchandra as I have now discovered that
    if I choose to print in colour only then the prints are perfect. It is only when
    the black toner cartridge is introduced that the vertical banding occurs.
    Thanks for getting back and sorry for my delay in getting back to you. Yes you are right regchandra as I have now discovered that if I choose to print with colour only then the prints are perfect. It is only when the black toner cartridge is introduced that the vertical banding occurs.
  • garrymgrant Jul 07, 2009
    Thanks for your assistance regchandra and it may indeed be the black developer roller - which I've no idea how to fix and will probably cost as much as the printer cost to begin with. I've been lucky and meantime used Loki's straw blowing tip which seems to have worked for the moment anyway. If the problem comes back maybe you could advise about cost and way to repair developer roller. Thanks again
  • Reg Chandra May 11, 2010
    is it only when printing black/white??
    Champion:
  • 220 Answers
Black developer roller is fault.need replacing.
Posted on Jul 06, 2009
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
White 1 inch vertical band on display
just a thought.. Either your Graphics card or your Video Card has gone bad.. unfortunately DELL has a tendency of putting the graphics ON-BOARD and IF the onboard grqaphics card is bad, you'll need to get into the BIOS and turn the onboard graphics off then purchase an after market Graphics driver.. IMPORTANT: make certain that the graphic cars is compatable with the DELL PC OR purchase a less Proprietary system
May 04, 2009 | Dell Dimension 9100 PC Desktop
Printer paper feed wheel rubber band is broken
I had the same problem. To remove the rubber band, I had to remove a plastic housing that keeps the band in place. It's a bit difficult, but I managed to without breaking anything with two small flat point screwdrivers. I couldn't find any original replacement part, so I looked for something similar in the market. The rubber has to be really soft to pick up the paper, also a reason why it cracks a lot. If the rubber is flat, then try to use fine sandpaper on it to give it some texture. clean it well, so it won't mess up the paper. Put the rubber band on the housing and clip it on. This should end with all the paper jams and weird noises. The job is easier done, if you remove the housing of the printer (six screws). Never use brute force. If it doesn't come out, there's something that you're doing wrong. Be patient, so you won't break anything. Good luck!
Feb 19, 2009 | Samsung ML 1610 Laser Printer
Samsung clp-500 paper feed roller replacement - how to...
You're on the right track! If you remove the paper tray and put the printer in a position so the front of it is facing up, you can then access the roller shaft with ease. If you now look on the right hand side of the roller shaft you will see a white plastic end which is secured onto the shaft with a little clip, lift this up and slide the plastic part inwards. This should now make the shaft easy to turn so you can release the two white clips on the roller and remove the rubber band (which there is only one of, but looks like two on a first glance). Once removed, I just turned it inside out so you can get another few months or more out of it before you have to buy a brand new one for a couple of ££. Replacement is just the reverse of removal. Hope this help!
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
White Streaks down left side of page.
Shake the toner hard and try again. It should work.
Dec 11, 2007 | Samsung ML 2010 Laser Printer
Misty white bands down the side of scan bed
That's a possibility If you were able to get these parts maybe the Microtek Technical support has some answers
Aug 05, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Non-printing gap/line down page
Hey Danzo, This error is usually caused by dirt (usually toner) on the laser lens. There should be a cleaner pad somewhere on your machine (though I am not totally familiar with Oki) that will wipe across the lens. If there is no pad, you may have to find access to the lens and wipe it manually with a tissue or similar
Mar 10, 2007 | OKI C5100n Laser Printer
Samsung CLX-2160N All-In-One Printer Logo
229 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
