Question about Acer Aspire 3690-2196 Notebook
Where can i get, and how do i install, a "firmware upgrade" for my e-machine PC to let it read SDHC cards?
  • Acer Master
  • 32,281 Answers
BIOS firmware upgrades are downloaded from the manufacturer's WEB site.
Use this link to get to the Acer support :-
http://www.acersupport.com/desktop/aspire/html/v55la2a_dl.html
Posted on Jun 30, 2009
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
My r4i -sdhc says that an eror has acourd
The problem is that you upgrade the 3DS console before upgrade r4i sdhc. Please following the below steps
1. Download latest r4i 3ds V1.60b firmware from official page http://r4i-sdhc.com/downloade.asp, and install it to the MicroSD card.2. Find a DS or DSi console, put the R4i SDHC 3DS card with MicroSD into the Ds or DSi console.3. Power on the console to enter the R4i main menu4. Choose the third button and click, you can enter next steps5. Press the "upgrade" button, you will enter the next steps6. Click "start" button to start the upgrade process.7. Wait about 2 minutes, the upgrade process finish.
r4i sdhc
Sep 25, 2012 | THQ Alex Rider: StormBreaker for DS
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
Gx7022e is there a firmware upgrade for my media reader on my computer so i can read sd hc camera cards?
nope. if it works with other cards but not with SDHC cards you need to buy a card reader, they are very cheap
Sep 30, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
DS Lite Blue Console: I load games on to r4i gold upgrade 2gb card they ...
Sounds like bad card stability. Why did you get the R4i Gold instead of the proven <a href="http://www.dscardworld.com">R4i SDHC</a>?
May 16, 2010 | Nintendo DS Lite Blue Console
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Is there a software upgrade so i can use a 4gb sdhc card
Upgrading from SD to SDHC is not a matter of firmware; it requires different hardware. No amount of firmware updates can allow an SD device to use SDHC cards.
Feb 16, 2010 | Polaroid iZone 300 Digital Camera
Is an SDHC card compatible with RNS-E
What's the exact RNS model you have, the RNS-510 ? Older equipment only supports SD cards, not SDHC (= SD High Capacity). And what's the exact SDHC card size & type ?
You might wanna try to format your SDHC card using FAT and/or FAT32 and try again. Also make sure the card is in read-only mode (workaround for some older firmware bugs).
And while testing, just use a couple of MP3/WMA files (so don't put tons of files on it) and remove all other files from the device to make sure it's not interfering.
If possible, try an older SD (non SDHC) card and/or contact your Audi dealer for a firmware-upgrade. Since you're having troubles with built-in functionality, this (possible) upgrade should be free of charge.
There are some rumors that some of the newer firmwares will only play DRM-enabled files, so you might wanna try that too (or ask your Audi dealer).
Mar 22, 2009 | 2009 Audi R8
SAMSUNG V800 SDHC CARD FIRMWARE UPGRADE
No. The differences between SD and SDHC goes beyond what firmware can change. It's possible to design a device to use both SD and SDHC cards, but a device that was only designed for SD cards cannot use SDHC cards without hardware changes.
Feb 05, 2009 | Samsung Digimax V800 Digital Camera
Using a sdhc card in a Panasonic DMC-FZ10
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Sorry
Dec 18, 2008 | Panasonic Lumix DMC-FZ10 Digital Camera
Acer Aspire 3690-2196 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
