Question about Dryers
Matag dryer#53-3540 dryer stopped mid cycle(not dry),won't restart
  • Anonymous Dec 31, 2007
    This dryer is crap. Everything Maytag makes these days is crap. Ours dies too. It's a thermal fuse that "cannot be reset".
  • Anonymous Jul 29, 2008
    Maytag Neptune md4000 electric dryer
5 Suggested Answers
  • 537 Answers
SOURCE: my dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
Posted on Apr 18, 2009
SOURCE: Dryer overheats, stops mid-cycle
Usually it is a thermostat that needs replacing. When the vent is clogged with lint it will usually finish the cycle but the clothes are still wet.
Posted on May 26, 2009
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
  • 8220 Answers
SOURCE: We have REX4634KQ1 that stopped working in mid
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Posted on Jan 08, 2010
How to fix dryer that will spin but not dry
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
Dryer drum stops turning mid-cycle
The belt may be in need of replacement.
Dec 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Dryer stops mid cycle
Do you have a blocked vent hose?
Oct 18, 2013 | Maytag Dryers
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
My dryer stopped mid drying cycle. The breaker in
Your dryer has an overtemp safety. Called a high limit, it has 2 wires connected to it, and usually is held in place by 1 screw. There will be a couple of them, the one closest to the element will be the bad one. It looks like a suppository, you'll see if you open up the unit yourself. DISCONNECT ALL POWER BEFORE ATTEMPTING ANY ELECTRICAL REPAIRS!!!!!!!!!!
Apr 11, 2010 | Maytag Performa PAV2200
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Jun 01, 2009 | Dryers
Hi, Will the dryer restart right away? Sounds like a motor going bad. With a model #, I can get you part#s if you need them. Is this a whirlpool brand?
Let me know if I can assist you further.
May 17, 2009 | Dryers
Dryers Logo
503 people viewed this question
Top Dryers Experts
