Question about HP Computers & Internet
A new G60-235DX will not locate and connect to my
A new HP G60-235DX laptop will not locate and connect to my Westell 327W gateway. The gateway is on channel 6. The gateway is on and currently working with and ethernet connection to another HP desktop.
  • refrazee Jun 30, 2009
    OS is Vista Home Premium. The gateway should be transmitting the SSID. Although I just today re-enabled the wireless port after 3 years of inactivity.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Windows Vista? Is the Gateway set to broadcast the SSID?
How to Disable ap isolation on westell 327w
Follow these four page guide to changing your 327W to bridge mode. This should solve your problem.
Changing your VersaLink 327W gateway to Bridge Mode High Speed Internet...
Dec 25, 2014 | Computers & Internet
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Westell 327W (Versalink)
you want to setup a peer to peer network using a workgroup. File sharing must be enabled in XP and Vista in order to share files. Temporarily disable the firewalls in Windows when setting up the shares....search on the Internet for setting up a Workgroup in XP
Jul 01, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
How to change wep security key
hi, sometimes if changes was done you need to recofingure you're wireless all over especially if the key has been saved on your pc to be rembered, you could actually reset your router and configure it by going to your routers gateway by doing an ipconfig you'd be able to see the gateway..launch it in your browser n youd be able to access the configuration of the versalink...i could actually give you more detail though im in a hurry, better you call your isp provider or bellsouth now att since westell versalink are manufactured by them and they give great tech support for connectivity problem...
Nov 28, 2007 | Westell Wirespeed VersaLink...
Computers & Internet Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
