Question about Ryobi Three Trimmer Combo
What is the fuel mixture on the ryobi cs30 weed eater?
  • Richard Tirado May 11, 2010
    Have you checked the cap (they used to have it printed on them)? I believe it's 50:1 but check the cap and let me know what you find.
  • 284 Answers
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Posted on Jul 01, 2009
What is the factory carbuerator settings for ryobi cs30 weed eater
The Walbro WYC-9 only adjustment is the idle speed. This is just slow enough for the trimmer head clutch to disengage.
Feb 04, 2015 | Ryobi Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the mix ratio on a ryobi cs30 weed whip?
I found a manual for this unit and it states that you use 2.6 ounces of oil mix to 1 gallon of fuel. Did a Google search for fuel and oil mixture ratio and with this calculator it came out to 50:1 mix. Do a Google search yourself and see if this is what you come up with.
Sep 21, 2010 | Garden
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
Have a Ryobi CS30 Weedeater, will not start, it is about a year old, did not see a spark, just bought new plug.
If you still don't have a spark with the new plug, then you may have a kill switch wire grounding the motor, keeping it from starting. If it's not that, then you have a bad ignition module (coil).
Jim
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi cs30 rope problem
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Mar 19, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Three Trimmer Combo  Logo
4,965 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
