SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
SOURCE: New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
SOURCE: I've changed the ink cartridge in my hp psc 2175
After you print the alignment page, you must place it into the scanner or document feeder, and press enter again.
Check the printhead carriage area:
Debris and Obstructions:
Ink Cartridges:
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
