Question about Toshiba Satellite A3 A355D-S6922 Notebook
Remove Bezel on Toshiba A355D-S6889
How do you remove then bezel to change the LCD on Toshiba A355D-S6889? The issue is around the area that the Screen folds onto the keyboard.
    Problem Solver:
  • 19 Answers
Ok, if you have never replaced a laptop screen before, you might not want to do this one first. It appears that the screws on the face of the screen have to come off first. They are under the rubber footies. After screws are out, tape them to a piece of paper, and label what they were for. Do this for all screws you remove, After screws are out, you will open the screen as far as it will go without forcing it. Using a plastic card, or similar PLASTIC tool, slide into the crack around the perimeter of the screen facia. You will hear "pops" as the snap clips are opened. The lower case of the laptop may also need to be removed. This repair is best left to someone with experience, so be careful to remember what screws go where. This is very important as a long screw in the wrong place will destroy your machine. Check out this page that sells parts for this machine:
http://www.laptoprepairparts.com/html/LRsearchmodelresults.asp?brand=toshiba&model=a355d-&txt=Satellite A355D series (A355D-S6881, A355D-S68811, A355D-S6885, A355D-S6887, A355D-S6889, A355D-S6921, A355D-S6922, A355D-S69221, A355D-S6930, A355D-S69301)
you will need to copy and paste since the website uses spaces, and the models were truncated. Without seeing the actual device in person, it would be difficult to walk you through it. Just remember how you took it apart, tape screws to paper with descriptions on where they went, protect against static, dust, water, and always use plastic tools to avoid scratches.
Posted on Jun 30, 2009
I have an Acer Extensa 5635. All the lights on the laptop work and i can hear the Windows sounds but the monitor doesn't show.. what do i do?
follow this steps and fix it. God bless you
    Power off your computer. Examine the bezel of your laptop, which is the perimeter surrounding the LCD display. There will be screws around the edges of the bezel, likely with screw covers on them, depending on your exact model. Pop off these screw covers using a knife tip, for example, and then remove all the bezel screws using a Phillips screwdriver. Put these screws in a safe place, such as a small plastic bag, because you will need them later.
      • 2
    Remove the bezel from the display. Pop it off by isolating a corner and peeling it off from there. Be careful not to bend or warp the bezel in the process.
      3 Disconnect the inverter cable. The inverter cable plugs into the inverter, which is located directly beside it. The inverter can be found beneath the bezel after it is removed, and directly below the center of the LCD display.
        • 4
      Remove the remaining screws. These screws are located in the metal brackets on either side of the laptop screen. These metal brackets are only visible once the bezel is removed. There should be two screws on each bracket, but this varies by model. Use your Phillips screwdriver to remove these screws, and put them in safe place, such as your plastic bag.
        • 5
      Pull the LCD display from the back plastic of the computer carefully, then remove the old display altogether. Slide the new display in and reconnect the inverter cable.
        • 6
      Replace the screws into each metal bracket, making sure to hold the new LCD display in place. Then, put the bezel into place over the LCD display. Replace all the screws and make sure they are tightly screwed into the bezel. Power the Toshiba laptop back on and enjoy your newly fixed hardware. Save any documentation that shipped with your replacement LCD display for later perusal or warranty purposes.
      Jul 31, 2013 | Computers & Internet
      I NEED A USERS MANUAL FOR A TOSHIBA LAPTOP SATELLITE A355D-56889
      You misread the model. It is a toshiba A355D s6889 S, not a 5. What is your specific problem?
      Sep 17, 2011 | Toshiba Computers & Internet
      I own an acer 10.1"
      it isnt that difficult actually , a how to for removing the lcd is shown here
      Remove the four screw caps and screws from the LCD Bezel.
      NOTE: The two center screw caps at the top of the bezel are for protection only.
      Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
      1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
      IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
      1. Disconnect the cable from the Camera Board as shown.
      1063_66_99.jpg Remove the Camera Board from the LCD Module.
      1. Remove the four securing screws (two each side) from the LCD Panel brackets.
      1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
      1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
      1. Remove the adhesive strips holding the MIC cable in place.
      1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
      1. Remove the adhesive strips holding the Camera cable in place.
      2. Remove the Camera cable from the LCD Module.
      1. Remove the adhesive strips holding the Antenna cables in place.
      1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
      to fit a new one do the steps in reverse
      If you found this info useful Please vote for me
      Apr 05, 2011 | Computers & Internet
      How can i replace my webcam plastic cover on my toshiba satellite L505?
      you may need to buy the whole bezel around the LCD, if you have the bezel you jus use a pry tool to open the plastics tabs around the LCD bezel.
      Mar 15, 2011 | Toshiba Satellite L505-S5966 Notebook
      I need to replace the LCD screen on my Toshiba Satellite P305D-S8828. Can you provide step by step guide with photos or a video?
      Replacing LCD is not a big deal. Just follow these steps:-
      1. Unplug your laptop and remove the battery pack.
      2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
      3. Remove the screw covers. Take care not to lose any. They pop off.
      4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
      5. Remove the inverter from the screen assembly. It is held on by tape in most models. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out.
      6. Disconnect the wires. One wire goes to the backlight, while the other goes to the video card.
      7.Use exact serial no. LCD for exact replacement.
      8. Connect the video wire and the backlight wireand affix it using the tape that held the original in place.
      9. Put the screen back in place if you need to, and snap the front bezel back on.
      10. Screw the front bezel screws back in, and place the screw covers back in place.
      Hope they work for you. All the best
      Dec 09, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
      Screen is dark but icons are barley visible.
      What you have is an inverter failure most likely. The inverter takes the AC adapter voltage and converts it to high voltage AC for the backlight bulb. Backlight bulbs rarely fail but the inverters do. Ebay has inverters for around 15-20 bucks. The inverter sits under the lcd panel behind the screen bezel. In most cases, removing the bezel is all you need to do to change the inverter out. Below is a link to the service manual for that model.
      When you click on the link go to page 4-61, this is the start of the lcd disassembly. I thing just 4 screws need to be removed and then take your finger nails and pry off the bezel in a small area and work your way around the screen until the bezel comes loose. When replacing the bezel always start at the bottom between the hinges and work your way up and around.
      http://tim.id.au/laptops/toshiba/satellite%20m50.pdf
      Jan 18, 2010 | Toshiba Satellite M55-S135 Notebook
      Laptop hinges are loose
      The hinges can be loose in two different areas, but the most popular is the hinge attachment point behind the screen bezel. Remove the rubber screw covers from the bezel, remove the screws, take your finger nailas and from the inside of the bezel pull gently to the outside to release the catches on the screen lid. Start on one side and work your way around the screen until the bezel pops loose. Look at the bottom of the screen and you will see the hinge attachment points. Tighten them up. If you have some locktite this would be a good time to apply it, remove the screws one at a time and replace. To replace the bezel, always start at the bottom and work your way up.
      Jan 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
      How to removing toshiba satellite a305-s6872 screen
      to remove the screen.... the front plastic bezel needs to be removed first.... Remove the rubber screw covers on the front of screen frame... then remove the screws.
      then use a plastic tool...like a credit card, start at a corner and pull the front bezel towards you .. you need to unsnap the plastic bezel... it is held on by snap locks all the way around it... Pull the front bezel frame off...
      then there are screws on each side of the screen holding it to the hinge post rails.... Unscrew them.... Tilt the screen forward from the top...
      Unplug the Display cable (it is taped on at the plug port..... pull tape downward)
      then unplug the LCD bulb Cable from the inverter...
      Dec 26, 2009 | Toshiba Satellite Laptop
      How do I remove the invertor from a Qosmio F20?
      The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
      The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
      The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
      Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
      Once the bezel is removed then you can get access to the inverter to remove it.
      Nov 16, 2009 | Toshiba Qosmio G15 Notebook
      Satellite A355D-S6889 LCD screen cracked 3 times
      I would suggest you get the main board checked. I can understand if replacing the screen thrice hasn't resolved the issue then either the cables / the main board must be the issue.
      Jul 28, 2009 | Toshiba Satellite A3 A355D-S6922 Notebook
      Toshiba Satellite A3 A355D-S6922 Notebook Logo
      389 people viewed this question
      Top Toshiba Computers & Internet Experts
      pankaj rautela
      pankaj rautela
      Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
