Question about Kenmore Washing Machines
Drainage is not working
Machine is not draining water while washing
    Sergeant:
    Champion:
  • 235 Answers
Either a belt is off the motor or a motor couple could be bad.
Posted on Jul 01, 2009
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Water is not draining or pumped out why ?
Do you have an HE or standard washing machine?
If its not draining on an HE machine you need to check the drainage port on it which is usually on the lower left hand side facing it. Beware there is water that will come out especially if there is water in the machine. There is probably a sock or some other items trapped in there making the drainage slow. The drainage filter on a standard machine varies depending on the brand. Usually they are on the back of your washing machine. I would check the drainage hose and the filter to see if there is any socks or other items stuck in them. That is usually the issue when the water isn't spinning out. Good luck
Nov 21, 2014 | Washing Machines
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
May 31, 2009 | Maytag Washing Machines
Washing machine inlet/drain problem
You may have a simple problem known as "siphoning". Have you checked your installation/ In particular, the drain hose? the following link explains how to check and correct a siphoning problem with a washer:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer drains as it tries to fill, its a drainage problem of some type. You may have a simple problem that is easily remedied. You may not require anything, but pulling the drain hose up out of the standpipe and repositioning it to ensure there is a proper air gap for drainage. I hope this helps you.
Aug 14, 2008 | Washing Machines
Washing Machines Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
