Question about HP LaserJet 3030 All-In-One Printer
Vertical lines about one half inch apart down center of the page when fed through the document feeder. No problem with fladbed copying or scanning.
    President:
  • HP Master
  • 1,314 Answers
If you open to document feeder and look at the glass when scanning via flatbed, just to the left will be a smaller piece of glass. That is the glass used when scanning through the feeder. Clean that glass as there is probably a couple of spots on it.
Posted on Jun 30, 2009
When we feed documents through the document feeder the copies come out blurred. We do not have that problem when we place the documents directly on the glass plate.
When paper is fed through the document feeder it scans the whole page on a little strip of glass about an inch wide and about 12 inches long. That strip has dirt on it that needs cleaned off. Lay the bad copy on the glass (face up) and you can line it up with that little glass and see where the lines match up. Clean that little glass with alcohol or glass cleaner and it will be fixed :)
Mar 31, 2015 | Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I get a singleline down the center of any scan i was told it was a blown pixel(?)
This could be cause by some debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans. Please refer to this article found in the Lexmark website about Vertical Lines Down the Page when Paper Fed via Autodocument Feeder (ADF).
Jul 24, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
HP c7280 scan 2 vertical lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Sep 20, 2009 | HP Scanjet 8250 Flatbed Scanner
Black vertical line in scans and copies when fed through top document feeder.
clean your scan glass (thin strip of glass running from front to back, underneath document feeder) with a soft cloth and alcohol.
Jul 16, 2009 | HP Officejet 5780 Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
HP LaserJet 3030 All-In-One Printer Logo
207 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
