Question about Mitsubishi Televison & Video
I have a Mitsubishi VS-6041 and the picture is fine when you turn it on, then after a few seconds, the screen gets this black square on it that covers 95% of the screen?
    President:
  • 788 Answers
From your symptom that you are describing, you most likely have text selected on your closed captioning.
You can confirm this by testing this theory, if you change channels, you will see the box go away for a while and then return.
If this is true then you will need to press the audio button on the remote until it indicates the CC option and change It to OFF or something other than text.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 30, 2009
  • John Snow
    John Snow Jul 02, 2009
    Did this help you with your specific television issue? I just wanted to follow up on this issue.
  • robandmegan May 13, 2011
    u r my frickin hero!!!!!!! i thought tv was doomed u have made me beyond happy
    1000 thumbs up ur a genious exACTLY RIGHT!!!! tytytyytytytytyyttytyytytytyttytyyTY
Mistubishi vs-6041 sound but no picture. Is it
it sounds like your speakers might be fried or just the wire loose or fried.
Sep 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS 6041. Just began having problems
Replace Both of your STK ICs example STK394-250 they are big black ics will have part number on them Call Mats 1-800-628-1118 for parts.
Sep 16, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
1995 mitsubishi big screen vs-6041
I have a copy of the owner's manual for my 6041. If you would like, I can scan it and email it to you.
--Ralph Dowling
plaintiff@comcast.net
Feb 02, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Vs 6041
Hello bgill,
At first I thought this was a problem with the bulb, but as I read further into your description of the problem the more it sounded like a control processor issue. The fact that the TV acts normal when the volume control is pressed, indicates that the control processor might be going bad, or at least some of the processor biasing circuitry might be going bad. The circuitry in question is somehow linked to either the bulb control circuitry.
You will have to have a qualified TV technician look at this set to determine what the problem is
I hope this helps,
Thank you,
Shuttle83.
Sep 17, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Tv
OK this is going to be either a tube problem or a convergence board problem, either way your going to have to get it serviced, unless your really electric savy and care to take it apart and solder pieces. There is no real fix to your problem without actually going "in"...
Black box on screen
This happened to me and it turned out the closed captioning on my TV were activated somehow. I never even touch the controls on the TV but I had to manually check the settings on the TV and found that the captions were on.
Sep 16, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Open Questions:
Televison & Video Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
