Question about Initial Global Navigation GM-510 GPS Receiver
Initial gm-510 gps has intermittent gps signal and loose antenna
Takes forever to acquire the gps signal and when it does it comes and goes. The antenna on the back seems somewhat loose.
    Brigadier General:
  • 4,090 Answers
Well a loose antenna can cause intermittent connections, but so can a low battery, despite it being plugged into a power source. Make sure battery is fully chatrged before use. I would suspect the battery chage first. Even get a new battery
Posted on Jun 30, 2009
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Where can i get free updates for initial 510 gps
try to consider to update by around $40 as minimum if failed to get free updates and have fine
Dec 16, 2009 | Initial GM-351 GPS Receiver
296 takes forever to acquire satalites.
If you don't use it very often it can take time to find its location. Have you tried using the 'set initial location' option? Once it knows roughly where it is and what time it is it can then work out which satellites it should be looking for instead of searching for any/all of them. The manual does say that it will take time if it has no initial clue as to where on the planet it is, and if you're on the move while it's trying to work that out then it may take even longer. Obviously, if it has a poor view of the sky, or if most of the satellites are behind you and you have a tin roofed aircraft then that will probably not help either.
Sep 24, 2009 | Garmin GPSMAP 295 GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Broken glass on gps unit Model GM-510
Did you try the company to see what it would cost to repair it.
Jan 31, 2009 | Initial Global Navigation GM-510 GPS...
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Initial Global Navigation GM-510 GPS Receiver Logo
533 people viewed this question
Top Initial GPS Experts
M_Butkus
ray gallant
Samuel O'Donoghue
Are you an Initial GPS Expert? Answer questions, earn points and help others
