Question about Digi Televison & Video
Can't access secret menu on digivox xl
When i enter 1004 to get into the secret meno to turn on emu nothing happens, does anyone know what code I need to use?? thanks in advance!
Go to main menu. Select system information. Then type in 1004.
Posted on Feb 26, 2010
Tip
Check your emu
right guys before you panic and start to look for the new keys or codes please check that the emu has not been turned off on your box ok so you have a box t press menu then 1570 this opens a new window or a hidden menu in this you will see nagravision and key emu highlighted scroll down to check that the emu has not been turned off accidently if so scroll over press>to turn on then exit exit if it is a digivox repeat the same procedure only key in 1004 and follow the same steps and again the same with the eurovox only again the difference is 1969 and again the same steps just check before you panic it could be an accident and the emu is turned off
on May 01, 2010 | Audio Players & Recorders
Tip
Box t eurovox or digivox
firstly be more helpfull on the type of box you have if you have loaded the latest firmware or not is it a cable box terrestrial box or sattelite box this info is most helpfull when trying to answer these questions step 1 you must first down load the latest firmware for the box you have if you download the wrong firmware you will corrupt the box or what they term as brick it step 2 after you have down loaded the firmware connect the box to your tv set and aerial/cable/dish these are connected with what are commonly known as F fittings step 3 scan your box you should have a manuall to explain how to do this for the box you are useing step 4 after you have completed the scan you must turn the emu on .on the box you are scanning step5 example if it is the boxT you scanned go to menu press 1570 this then opens a hidden menu on the very bottom you will see key emu left or right press on the > < to turn the emu on after you turn the emu on press exit exit back to main screen you should at this stage have everything working if not redo step 2 on again HINT if you cannot access the hidden menu then you have not installed the latest firmware you cannot access the emu without the firmware been loaded first right hopefully you have all this done and you have your channels happy viewing last hints for you BOX T access code is 1570 .. EUROVOX access code is 1969 ...DIGIVOX code is 1004 now hope this helps
on Apr 25, 2010 | Audio Players & Recorders
Didgivox cant get into secret menu
Its easy press the menu button, the scroll down to system information press ok till the system data comes up, then press 1004 while you are keying in 1004 the will be no signs to say your entering it, but when you press 4 the menu will pop up read what i just wrote carefully an it should work if it doesn't then something is up i got a digivox xl black Good luck.
Sep 15, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
Just bought a digivox-t but channels are scrambled,
Type in '1004' as before to get secret menu on system info.
Ch@rus = 5E01
00 = CE 19 2E 87 80 61 74 90
01 = AA 26 9E F2 E9 14 D1 AE
Hope this solves your problem.
Mar 31, 2009 | StarTech.com StarView SV211K 2-port KVM...
How do i get in to menu on digivox to install codes
go to remote, press menu
key in code 1004
provider id 5401
00
change keys to - b0 b8 4f 04 e6 5f 87 80
press ok button (on remote)
press exit
Dec 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
Digivox Box
tyr 1570 then turn on your nagra vision
Dec 19, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Digivox chorus codes 18/12/08
chorus 00:CE 19 2E 87 80 61 74 90 01:62 FA D9 F3 CE 05 FA 79
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Putting codes into digivox xl
GOTO MENU THEN GO TO SYSTEM INFORMATION AND PRESS OKAY THEN POINT REMOTE AT BOX AND TYPE 1004 THIS SHOULD TAKE YOU INTO A NEW MENU GO TO NAGRAVISION AND PRESS OKAY NOW USE THE LEFT RIGHT BUTTONS TO SELECT EITHER NTL-TELEWEST-C&W USE THE UP DOWN BUTTONS TO GO TO THE CODE AND CHANGE IT THE LETTERS A,B,C,D,E,F SHOULD BE COLOUR CODED IF NOT USE PAUSE TO ENTER A AUDIO TO ENTER B RED FOR C GREEN FOR D YELLOW FOR E BLUE FOR F AND USE THE NUMBERS REQUIRED TO MAKE THE CODE THEN PRESS OKAY THIS SHOULD STORE THE CODE THEN EXIT BACK TO THE TV IF THE CODE DOES NOT WORK TRY ANOTHER HOPE THIS HELPS.
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
377 people viewed this question
Top Digi Televison & Video Experts
Marvin
Marvin
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
