Question about Ruud UBHC Air Conditioner
My outside ac unit fan will not blow?
A guy looked at it and told my husband and I it was the switchboard, and he rewired it and it worked great now the fan will not turn on again. What should I do?
    Scholar:
  • 70 Answers
You have no choice but to call a tech or the guy that rewired it. Sounds like motor was the problem that caused the board trouble. If this is a heat pump you will need to get the defrost board checked out and motor repaired or replaced and wired back up right or it will not work in heating when it is time to defrost coil in winter Motor may have been off on over load protector. Bad bearings will cause motor to overheat and shut down. Bad bearings are the main cause of motor failures.
Posted on Jun 30, 2009
    Sergeant:
    Champion:
  • 235 Answers
You might have a bad fan relay. Wait til the unit cools down and then restart. If the fan comes on then the fan is going out. Shuts off when it heats up.
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Blower not working
Check all of the wiring connections from your fan motor. If 1 was OK before, there shouldn't be any reason its not now. Closely check the connections going to the capacitor. If they are back to front, the fan wont start, it will sit there humming. If you give it a flick and the fan starts up, it will be that connection.
Nov 25, 2013 | Goodman Heating & Cooling
Exterior CKL49-1A AC Unit not blowing cold air
Why you need to change evaporator coil when condenser fan not working ,also why would you even charge unit with looking for leak.
Maybe the evaporator coil is leaking and when you recharge it it work for couple of days now unit is empty again .
If unit have low pressure switch then outside unit would shut off.
Jan 05, 2018 | Coleman Heating & Cooling
Our AC unit is on inside the house but blowing hot air. Outside unit is not on. My husband tried to turn the fan blades on the OS unit and it won't turn. Is the fan motor gone?
It is a strong possibility. Use some oil on the motor.34a4ac9.jpgIt might be the contactorace24b7.jpg
Before he goes messing with anything inside the unit he needs to kill the power. It may be the capacitor, look for a swollen cap45d0615.jpg06e208f.jpg
Aug 22, 2010 | Intertherm Heating & Cooling
Sometimes, when the inside blower shuts down, the outside compressor and fan motor continue to run for some time. Other times, when the inside fan motor is running, the outside fan and compressor motors...
The thermostat has a timer on the on- cycle (5 min delay for the outside unit and blower inside) if you are not gonna call a service guy then ( for $25) you can go to homedepot (whatever you got out there) and buy a honeywell vertical digital heat and ac t'stat.
this one doesnt require you to set it up for a particular application. this may solve your problem. but as for warm air out of the registers you need a service guy to check that
Mar 27, 2010 | Ruud UAKA060 Air Conditioner
If the fan on my A/C Unit isn't working will it cause the a/c to blow room temp air. This unit is around 30yrs old
Yes. I assume you have a centeral AC system and the outside unit's ( condensor) fan does not blow. That fan exchanges the heat from your home with the air outside. It is probably a bad capacitor but may be the motor. You can damage your compressor by operating it without the fan working.
Aug 05, 2009 | Heating & Cooling
A/c blowing hot
All models with ac use freon r134a
May 29, 2009 | 2001 Chevrolet Malibu
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
What's wrong with it?
There are lots of things that could be wrong since he just changed the contactor a wire may have burned...Very common..Make sure all wires feel snug onto terminals. The compressor run capacitor may also be bad it looks like a batter with 2 or 3 terminals if it looks bulged on the top where the wires are than its bad ...if it looks flat you would have to have a meter that checks capacitors to test it. Those are all the easy items to correct..Call for service if all cks ok Please rate my solutuion as solved if you appreciate my expert advise>>>>>>>
Oct 03, 2007 | Goodman CLQ36AR49 Air Conditioner
Ruud UBHC Air Conditioner Logo
340 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
