The blades on my craftsman 22hp OHV GT5000 won't engage. The last time I used it ,it worked fine . When pull the engage button the engine starts to run rough like it 's going to die . I checked the belt it's ok.
I would check to make sure that the pullys are free. With it off reach under and see if both or more blades turn freely. If the bearing is frozen it would cause this problem.
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
