Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
I lost the owner's manual. I don't know how much
I lost the owner's manual. I don't know how much cleaner to mix with the water
  • yadayada
    yadayada May 11, 2010
    it says on the bottle of cleaner what the mix ratio is.
Located on the back side of the plastic container in which the formula and water is mixed into has an indicator for the formula and a separate indicator for the water. You should be able to obtain a copy of the manual from the Bissell website.
Posted on Jun 30, 2009
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Lost instructions on how to use my dirt devil platinum force carpet cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=852232
Generic problem for all Vacuums
Posted by Brad63ford on July 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owners manual is from Royal itself and to contact the Royal factory @ the phone # listed below and to give them the brand name and model # in order to get the correct owner’s manual for your particular vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Lost Manual
Try this URL:
http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
Then click on "User Guide PDF". A pdf of the owner's manual will download.
Jul 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No manual
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=797691
No manual
Posted by mwood16 on July 17, 2008
We lost our manual for our Hoover steam vac; set it up and water doesn't release. What’s the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can get the owner’s manual from the Hoover factory that I will list below and as per the water doesn’t release, it could be the trigger assm that maybe got disconnected and or broken and that could be why the water is not coming out. If you purchased it less than one year it would be covered under the one year Hoover factory warranty, so free to contact your local vacuum cleaner dealer or the Hoover fact website or cust serv @ the phone # listed below.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
DONT KNOW HOW TO CHANGE MY BELT
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698891
Posted by mommyhop1 on Jun 23, 2008
I LOST MY MANUAL TO SEE HOW TO CHANGE MY BELT. TRYING TO FIND THE USERS MANUAL FOR MY ELECTROLUX 3500 SR
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owner’s manual is to contact the Electrolux factory and either download the owners manual from the website or call the customer service phone # and give them the model and serial # of the machine and they will send you out an owners manual for the product. Or you can contact your local vacuum cleaner dealer in your area and they would assist you in changing your belt. Usually there are screws in the bottom of the vacuum and either the bottom will come off or the top cover will lift off and then you can change the belt. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Little green machine solution
on the solution tank of the green machine has a line on ot showing how much solution
May 11, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
No cleaner or water will squirt out when I am shampooing. Yes, I have plenty of water, cleaner, power and set on floor cleaning bissell proheater 2X
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=556844
Posted by sherski3 on Apr 29, 2008
No cleaner or water will squirt out when I am shampooing. Yes, I have plenty of water, cleaner, power and set on floor cleaning Bissell proheater 2X
Bissell 9500 ProHeat 2X Clean Shot Upright
This could be that you have a defective water valve assm below the water tank or the trigger assm is not working properly or not connected. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owners manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do i put the soap?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073
Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in?
Do i mix the soap in with the water in this compartment or is there another location where i add the soap..
We have looked the machine over and see no other place to really put the soap...
will it ruin the machine if we just add the soap with the water in the detachable compartment?
According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together.
You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
293 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
