Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi EX26 dies when hot, won't start, then when cool starts
My ryobi ex26 acts like it vapor locks. It runs OK until hot then dies and won't start until it cools. Then it happens over again.
  • 1,041 Answers
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Nov 26, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
It could be the coil going out. Once it gets cool it will start up fine but when it overheats it will quit.
Posted on Jul 06, 2009
Can't locate H and L screws to tune Ryobi EX26. There's a screwdriver slot cut in the plastic cover, but screws have no slots, or are capped.
you probably have the type that requires a special tool, poulon engines are known to need one. check with your local Lawn mower repair shop, they are the only ones that will have one
Sep 12, 2010 | Garden
Ryobi EX26 will not start. I replaced spark plug and primer bulb. Even used starting fluid. It will fire up for a few seconds and then die. Help please!
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 31, 2010 | Garden
I can't restart my Ryobi cutter once it's been running.
This is because Ryobi uses a loose fit on their piston and cylinder. As the cylinder heats up it grows in size causing the compression to drop.
when the cylinder cools the cylinder shrinks and you regain your compression.
Another possibility is that you are boiling yoour gas causing a vapor lock. This also goes away once the unit cools.
Sep 10, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
Jun 23, 2009 | Ryobi 15" Electric Factory Reconditioned...
My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
Jun 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi RLT 30 CES Strimmer - Won't run properl7
I'm not sure about the carb. adjustment being removed. The newer carbs. only have one dial for adjustment, not the two screws like the "old school kind".It probably needs the carb. cleaned. Disassemble the carb. and clean with carb. cleaner. Use a Den Tek Brush, (used for cleaning teeth), to clean the small portals. Make sure the small screen in carb. is free of debis. The smallest of particals can cause your problem. Reassemble and try starting. If it still acts up, buy a carb. kit for trimmer and replace the needle valve, appropriate gaskets, diaphragm, and small screen. This should solve the problem.
Jim
May 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,882 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
