Installing Mother board on HP Provillion ZE 1250
I've removed all the screws I can find but can't lift keyboard from bttom of laptop, to get access to mother board. What is holding it together and what can I do about it?
  • ekal Nov 08, 2007
    I found the panel you mentioned and removed four or five more screws. Now something is holding the keyboard in place. Does it slide out to the side somehow, os is there another screw or two in the center that I can't see?
    President:
  • 317 Answers
Keyboard typically have to be removed from the top. You have to remove the panel that's near the top of the keyboard, right below the display. Then there will be a couple screws in there.
Posted on Nov 08, 2007
  • Peter Burns Nov 08, 2007
    Once you get all the screws out it should just lift right out. If it still won't come out you're probably missing a screw. Then under the keyboard there will be a cable connecting it to the motherboard.
How do I access my HP G60 533CL laptop in order to replace the keyboard? I don't want to break anything in the process. I have the replacement keyboard.
A link to the Manual is above. Check page 4-18 (57 in the PDF reader) for keyboard removal instructions. Good luck.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jul 18, 2011 | Computers & Internet
Hp nx 6120 laptop asking for administrator password at post screen , how to remove that password, plz suggest me
NC6120remove the the cmos battery under the keyboard for 5 minutes i wait like 10 or 15. that will reset your cmos removing any cmos passwords its a simple fix. just remove the keyboard screws from the bottom and push down the tabs on the top of the keyboard and lift to remove. becarefull not to pull on the cable connecting the keyboard to the mother board to hard of a tug and you can brake the lever thing holding it down and then your keyboard might not work. just be patient and never force anything it should all come lose easy. all i used was a small sized flat head screw driver. if you need more help message me and i will make a video of how to do it.
Nov 25, 2010 | HP Compaq nc6120 Notebook
Where is clock battery in my laptop compaq presario 1246
Remove the touchpad screws on the bottom of the laptop. Lift the touchpad and the keyboard. Remove the flat metal heatpipe above the CPU (3 screws). On the bottom left, just above the HDD you should see a small circuit board held by 3 screws. Remove these, lift the circuit board and there you go, the battery is there.
Dec 14, 2009 | HP (158800-001) for Compaq Presario 1246,...
How do I disassemble the key board?
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Toshiba Satellite A135-S4527 Notebook
Replacement of keyboard on a hp ze 5000 laptop
My buddy and i put together a video a while ago for this you can find it here
This is not your model but the concept is the same.
Disclaimer: careful bad things can happen, not responsible etc etc :)
good luck and tell me how it goes, please don't forget to rate.
Nov 13, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Acer aspire 3050 black
refer to ur user manual to see which key for brightness e.g.fn+f 9
(reduce brightness)if havnt got one can easily download one of net.try to swich screen to monitor.connect external moniter and press fn+f 5.(refer to manual maybe different key)
press down and release screen lid button see if any response.if all fail need to disassemble.
remove screw in about middle of pc underneath.this ia retainer screw for key board.remove screws dirrectly behind screen to remove plate with buttons.then can get access to keyboard and lift away (do not disconnect it just rest it on screen or front of pc )check cables from mother board to screen.check inverter.
all these are worth checking but initially sounds like inverter faulty.
Mar 05, 2008 | Computers & Internet
Installing 1GB Memory
the problem is will your processor read 1GB of random acess memory. install you open the laptop remove the screws and access the mother board push down the usually white clips and lift the ram straight out, when installing make sure you ease the stick into the socket and when you have it against the bottom push it firmly until the clips lock back into place.
Dec 09, 2007 | HP Compaq Presario V2000 Notebook
How do i remove the keyboard
Usually you can remove the panel right above the keyboard, this will allow you to access the keyboard screws. The keyboard should swing up allowing you to unplug and remove it.
Nov 26, 2007 | Toshiba Satellite A55-S1066 Notebook
Use this link for a video tutorial from HP.
In the list you will find a choice for keyboard.
http://h20181.www2.hp.com/plmcontent/NACSC/SML/results.htm?SID=384511&MEID=F2DAF231-84E4-4AE7-BE71-BB1CA8A20D6A
There are other videos listed there as well that may be usefull. Hope this helps.
Oct 30, 2007 | Compaq Presario V5102NR Notebook
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
