Question about Kenmore 75944 Gas Dryer
I replced ingnitor in my kemore gas dryer but not flame
I replced ingnitor in my kemore gas dryer but still n o flame ... i don't hear the click to start flame
  • 97 Answers
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Posted on Jun 30, 2009
  • MrQuickFixit Jun 30, 2009
    Hello Friend, I also want to let you know that if you replaced your igniter and it's not glowing at all, Then your problem is a thermal fuse located under the back cover of your dryer. Just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Happy to help, Tim. And please don't forget to give me your rating for my help.
Repair t 4000
You did not state whether the flame ignites or not. If it doesn't, the check to make sure the gas line to the dryer is not turned off. You should hear the gas valve "click" while the ignite is glowing.
You can "crack" the gas line at the value to make sure gas is going to the valve.
If you have gas at the value, and do not hear the click, then the gas valve is not opening. Either the valve or the controller is not working.
If you are getting a flame but it goes out quickly, then it is possible the flame sensor is bad.
If you do not feel comfortable doing this, call a qualified appliance repairer technic
Apr 21, 2014 | Kenmore Dryers
Drum rotates no heat,igniter dosent start
While the drum is rotating you should hear the CLICK associated with the gas valve assembly powering up to give out a blast of heat. If ya don't hear no click check the duct fuse. Right next to the control thermostat. If it is blown it kills the circuit to the gas valve assembly. If that fuse is good and the control is also good, then check the flame sensor for continuity, If it is open then the ignitor won't glow. The ignitor must glow and change in resistance then the flame sensor must open up and kill power to the ignitor so that power will be shifted to them coils on the gas valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 03, 2011 | Maytag MDG2706A Gas Dryer
My gas dryer will not get warm
Can you hear the flame come on at all? If you can hear the flame come on in the beginning but then as time goes on it doesn't, you need to replace both coils (solenoids) on the gas valve.
Take the front panel off and watch the operation of the dryer. You should see the glow from the ignitor come on and get very hot, then hear the click of the coil releasing the gas, which will allow the flame to ignite. If you see the flame come on, stay there and keep an eye on the time.
After about 5 minutes if the coils click but the flame doesn't come on, you've just proved you need the coils.
If you have a meter you can check for continuity or ohm out the ignitor to see if that is your culprit. A less likely repair would be to replace the flame sensor.
Feb 19, 2011 | Kenmore Dryers
Clothes not drying? thermostat location for replacement? Kemore Dryer Mod#110.72722101
95a0bfb.jpgab8d574.jpgIf that fuse is blown that dryer will run but no power will go to the gas valve,ignitor, or flame sensor.410791d.jpg
Jun 10, 2010 | Dryers
Dryer is not getting hot
These dryers have an auto spark ingnitor just like a gas stove. They do go bad and need replacement. Upon turning on your dryer, you should hear the ignitor click at least once to ignite the burner. If not I would check the continuity to that ignitor first
Jan 22, 2010 | Fisher and Paykel DE27CW1 Electric Dryer
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Kenmore 75944 Gas Dryer Logo
348 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
